- Joined
- Oct 4, 2008
- Threads
- 193
- Messages
- 6,211
I have noticed recently that my '96 FZJ80 has been reluctant to start lately, several cycles of the ignition swith were required to start on occassion. Other times it would start normally.
Today I started it and noticed the annunciator/warning lights on dash did not go out shortly after start and I heard a sound coming from under hood. It was the starter, it was still spinning. I'm guessing the relay got stuck since I tried to shut the ignition switch off but the engine kept running. The only way to shut it off was to turn off the battery quick disconect I recently installed on the + terminal.
Now here's the kicker, I tried to drive it home like this... half way there it started sputtering and surging???? Like a fuel issue or computer control issue, it got progressively worse then it just stopped and the starter motor stopped spinning. After this it drove normally but my Scan Gauge II OBD computer would not give any info. Once home, I shut it down & tried to re-start it. Surprisingly, it did but with an aweful noise.
I'm sure that I need a new starter but what else should I check? Ignition switch? Computer control unit?
Any thoughts or similar experiences? Please let me know.
Thanks a bunch!
Thanks a bunch!
