95 running poorly/not running long post
The wife has been driving the 80 during the recent snow. Today she filled it up with gas and went on her day. About 10 miles after filling up (20 gallons) she called and said it was losing power.
I met her and it was fine. I drove it to the parts store to get some seafoam just in case it was bad gas.
While idling at the parts store it started loping and almost died. I increased the rpm and it cleared up.
About a half mile down the road it lost power. It couldn't pull away from a stop sign. It wouldn't die, but no matter what I did it wouldn't clear up. I limped it to a parking lot And played with the throttle. It finally cleared up and I made it home.
I let it sit while I ate dinner and when I went back outside it was doing the same thing. Once it warmed up tho, it acted up less. It always starts back up, but it may not be running right when it does.
It's run perfect for the year and a half I've had it. Of the 3 80s ive owned it's the strongest running with the least issues. It's never had an issue actually.
Plugs, wires , cap, etc are a year old. Egr is inoperable. Wiring looks good. Cats are gone. I haven't changed the fuel filter and I'm assuming the fuel pump is the original. I HAVE checked the fuel pump relay, that isnt the issue.
Could this be a case of bad gas and a clogged filter or do y'all think getting gas right beforehand is just a coincidence.
I'm open to any and all suggestions, and thanks in advance.
Will
Can I mix the bg stuff with seafoam?
Sounds like bad gas. Weather permitting, try to take a sample off the bottom of the tank. Simple to do, just loosen the plug on the bottom of the tank. If the fuel is cloudy or contains water, then drain until clear and change fuel filter. If bad fuel is suspect, contact the gas station, let them know your findings and send them a repair bill. I wouldn't throw fuel additives into bad gas. Your gas probably has ethanol in it and phase separation has occurred and only adding more ethanol or draining it will solve the problem.
I've already put the seafoam in. It's like it forgets to accelerate. I push the gas and nothing happens.
I'll check the gas and report back what I find.
Thanks again
Will
I don't know if the Throttle Position Sensor (TPS) would cause these exact symptoms, but it's a definite maybe if the fuel test good. I had two Mustangs (93-98) that had TPS issues, but the symptom were wondering idle, erratic and stumbling acceleration.
Drained a little of the gas today. The bucket I used had some trace water that I couldn't get out even with a rag. Long story on whyI used that bucket made short is that I only had 10 minutes to do it.
Anyways, I drained about a gallon out and about 1/2 of the bottom of the bucket is covered in water. Much more than could have possibly been trace stuff from the water already In the bucket.
I'm gonna pull the pump out and check the fuel sock and such and see if I see more water in the tank and then I'll drain the tank and change the fuel filter.
Hopefully this fixes it. But knowing my luck, it won't.
Thanks again for all the help.
Will
The engine didn't get wet. It was driven the entire time it was snowing. With the exception of nighttime. However, I will check it, as that does make sense.
Thanks again
Will
