95 injector harness question
West MI near GVSU
Website
www.mcdesignsoffroad.com
I just finished neatly wrapping up the injector harness on my wife's 80 when I realized that the two rear injector pigtail/plugs I just soldered on were taped so that they were too short. So I cut the tape and heat wrap far enough back for them to safely reach and re-taped the harness.
I lost track of which plug goes to which injector-#5 and #6.
Do the 1fze injectors operate sequentially or are they "gang fired"?
If like the 96 (likely), then original harness wires to each injector for GND side switching (all injectors get a common black/red for +12V power):
Inj 1 white/blue
Inj 2 white/red
Inj 3 white/green
Inj 4 yellow
Inj 5 yellow/red
Inj 6 yellow/blue
cheers,
george.
I've already spliced in the new pigtails; 5 of them. I had five plugs that wouldn't clip down and the #1 injector plastic had broken and is now replaced. Last year we had the head done and to keep the plugs on the injectors I had to carefully zip tie them on.
If I ever do anything more engine wise, it will be to swap in a 5.3 or 6.0. Then there will be a moderately broken in rebuilt 1fze available...
The housings at this point are hard and brittle. They really aren't that expensive and removing the old housing is as simple as using a pair of slip joint pliers and cracking them open like walnuts. Just replacing the housings is likely cheaper and less work than what you did and in my opinion a better repair. I only point this out for people who search this subject in the future.
