94 Catalytic Converter question
Auburn, CA
Website
stellarbuilt.com
Looking to update my cats.
Any reason why these wouldn't fit, same 4.5 from 93 on......
MagnaFlow 447103 Large Stainless Steel CA Legal Direct Fit Catalytic Converte: http://www.amazon.com/MagnaFlow-447103-Stainless-Catalytic-Converter/dp/B00AURRN4E/?tag=ihco-20
I understand these are for 95 and up where the cats were in series, 94 had them side by side.
Seeing how this is a pre ODB2 rig, in CA....
Could I run these? There doesn't seem to be a Magnaflow complete with down pipes for 94's just universal cats..
I'd rather not have them at all.... but alas wonderful CA.... If i must I'd rather have them inline where I can tuck them up better then side by side.
-A
New cats are 3- way, so don't really need 2 cats on any of these rigs any more. Just gotta pleaz the smog nazis. Check w local smog referee to see if they will allow it if you show a receipt that documents the new 3 way cat?
Good info thanks.
Really wondering then why the 95 Y isn't listed for 94 also... Again same 4.5, so one would think it would bolt right up.
If that's the case I could just run that with one cat...
Anyone done that?
-A
A bunch of us are doing it on 95-97 OBD2 rigs, but Az does not do a visual inspection under the rig. I thought someone on here had done this on a 93-94. 95s. Should work too, as they are OBD2 but test as OBD1.
Inkpot,
Thanks, I don't see why it wouldn't work. My only concern is if for some funny reason the Y is diff 94 vs. 95...
Not a huge deal to cut and weld it make it fit. But even better if it bolts directly up.
94's are nice cause the 02's are pre cat in the system... I think 95 and one has one on both sides?
If anything might have to weld an extra 02 bung fore of the cat.
-A
If you pull the PAIR system out, you'll have your place for the O2 sensor ;)
