94 burning oil?????
Montana
I purchased this rig (1994 w/300k mi) this summer to use as a family vehicle. I fixed all the oil leaks and it runs amazing well; no problem running 80mph on the interstate and starts right up at 0 deg F without being plugged in.
But it burns a lot of oil at highway speed. About 1 qt / 100 miles. It seams to smoke when accelerating.
Is there anything other than rings that this could be?
It has a new PCV valve.
I just don't have the time to do a LS swap right now so if I can't find an easy solution I am going to have to sell it. :frown:
You got one of the rare Hybrid Fzj80's. It burns both gas and oil. Seriously though, it's either rings, leaking valve guides or cylinder wear. If it were me... I would do a leak down test
I have half the mileage on mine and I burn about a quart every 2 tanks of gas (~500 miles). They are known to burn a good amount of oil for sure. Leak down should tell you where it is going. Might want to try using thicker oil. I've heard synthetic is better and I've also heard dyno is better... I don't really know. I've been burning more it seems since I've moved to synthetic though.
My 200K 80 had valve stem seals replaced about 30K ago when I did the HG. It's hard to tell if it has burnt more than a few tablespoons after 5K miles. These can be very tight engines.
I initially tried 15w40, then added motor honey, now am adding 25w50 that was collecting dust.
We tend to drive 300mi most weekends so I have had the chance to try several different flavors and use up all my extra/odd oil.
Make sure the PCV valve is installed correctly. Could also do a catch can between the PCV and throttle body to see how much oil you're getting through that system.
My 96 burn no oil between the 7500 mile oil changes. Quaker state 5W30.
Head gasket done at 145k. Now at 251k.
Otherwise I would guess the valve guides and seals.
Can a pcv valve be installed incorrectly in one of these?
I like the idea of a catch can on those 2 lines going to the intake.
245k miles now, head gasket done at 180k.
I don't add oil between oil changes 5k mile intervals, Oil stays at full mark. I once did a 10k on the same oil just to see if it would burn anything but ended up not needing to add a single drop. As others have suggested a leak down test would point you in the right direction but my money is on the valve seals. I run Mobil 1 0w40 out of convenience since my wife's cars needs it anyway.
Does it smoke when you first crank it? Does it smoke with very light acceleration after idling at a stoplight?
It smokes under acceleration. The heavier the acceleration and higher RPM the worse it is.
I'm not sure on startup but if I let it idle for a while it leaves a black spot in the snow under the tailpipe.
I could be wrong, but with that info I think it is your rings. My experience with bad valve seals is very noticeable smoke at start up and while pulling away from idling. There was no smoke when accelerating. Definitely none under heavy acceleration.
Under hard acceleration manifold pressure is high and vacuum low. At this point cylinder pressure is also high which points to the rings. At 271k mine uses no oil like some of the others who have posted here. I hope it's not your rings but if it is, that points to a period of poor maintenance during the life of the vehicle which, IMO, should be a punishable crime. Let us know what you find.
I have had mine for 30k. It now has 223k. It has always burned oil. Now it is fluctuating between city/hwy as to how much. Definitely up to two qts on hwy trips of 1000 miles. The one thing I did in the beginning to help was to switch to Delvac. It is a huge difference if I switch back to standard viscosity. Drinks oil. I suspect an overhaul is in order but I will be going another route. Try Delvac......it cant hurt and it is rated for gassers.
I was burning almost 1qt per 1,000 miles until my head gasket blow and I had the head rebuilt. I now burn about 1/2qt over 4k running Mobil1 syn high mileage 10w-30 in winter and 10w-40 summer. I never noticed any smoking. Worn valve seals can burn a surprising amount of oil with no indication.
