94 80 Series Tranny Control Problems
Lawrence County Bama
Please help me save Trigger. He's got 290K on him and has lived a hard life but I'm not gonna shoot him yet. Just got back from a 1400 mile road trip, ran like a champ as always got in around 2000 last Sunday and put him up as usual. Jumped in to go to work the next morning and the Speedo didn't work. On the way into work I notice the OD light blinking like a CPU code light would only steady and the whole time I'm running. It was going into overdrive just fine, seemed to run OK, just not cruise...I guess the speedo is pretty paramount to its operation..:doh:. Anyway, by last Wednesday the engine is sputtering from a stoplight, he's becoming hard to crank, mileage is down to about 10 from 13. I figure I've fried or broken a wire on the Tranny control module or input lines, but, where is this thing? I've cleaned the connector at the tail shaft house on the tranny but he is my only wheels right now and I can't take him to parade rest just yet. My questions are, is the Tranmission controled by a separate computer from the ECM? If so, where is it? Does it fail? May sound silly but I know toyotas and even thier electronics don't fail often if at all. If the tranny controls are integral to the ECM, is there anything I can check short of replacing the computer? I've poured over this site for a few days and I have found nothing similar. This frightens the **** out of me. If I had a shop I wouldn't even blink, but I just relocated and I'm in a friggen apartment complex so major work is voodoo here. Any help is greatly appreciated. I can't get rid of him, after seeing Kirks work, he is destined for grandeur one day after I have a shop again. If I have violated any etiquette here, please let me know how to ask this.
Tango Yankee fellow Crusher Pilots, glad I found you.
Dunman
Wire harness internal damage at the back of the engine by the EGR valve?
Thanks for the input fellows...
CJF -- Exactly what I thought initially, but why didn't it start while I was still on the road? I'm gonna run the Tranny harness down and inspect it after I pull codes as long as that turns up no clue.
You guys have made me come to the conclusion it is time to cough up the bucks for a code scanner....so I'm headed out to get one now. I did find out that the TCM is located just forward of the ignition switch mounted on the starboard side of the steering column. Anybody know how to pull codes exclusively from the TCM or do I start easter egging after I get the scanner?
Wish me luck and I'll keep you guy apprised of what I find.
Dunman
You possibly have two separate issues:
1) Busted speedometer, due to which both the cruise control and the tranny are not happy.
2) Unrelated engine trouble that is potentially more serious.
At the very least though, track down where exactly the speedo trouble is; that's the one thing you *know* is wrong, and could conceivably be the root of everything.
Oh, and we need to know what year ya got. (Edit: 94; it's in the thread title.)
Pretty sure a scanner can *not* be used on a 94; we had someone claim otherwise recently, but when I asked him more about it I don't recall getting an answer.
Engine and tranny codes for your year are pulled using a simple paperclip as a jumper wire.
Curtis
Search around here .. there is a thread that explain how to count and recognice the codes .. and the meaning of those codes.
Thought you already check the usuals .. as oil level.
Yes, you are right to my chagrin, a 94 does not support OBDII diagnostics. Anybody got a good diagram depicting the pins to short with the 200 dollar paper clip that just bought to extract the codes? I'll look around for the secret squirrel decoder ring for the blink translations. Oh well, I've always thought I needed one of those stinking scanners so now I have one. The thing that kicks me in the A$$ is the fact that I remember toyota being one of the "early compliance" manufacturers but then again I'm sure that was probably on CONUS built Yodas. And yes I have checked the normal things.....I guess it's like admitting you did your cousin once but back in the day (circa 1984) I was a Mr. Goodwrench so I'm pretty adamant about checking the simple stuff first. KISS is the principle. I'll explain if you don't know it. Anyway, I've got a GF around here these days with a dry garage so I guess I'll go pull ole Trigger in there this weekend and pull him down as far as I dare to run down the Tranny harness and the TCM to look for the simple stuff like loose connections. I've been through the dash before when I replaced the evaporator and I'm looking sooooo much forward to doing it again. I'll let you guys know what I find. I'll even take some pics so that the next poor dude that has to venture North of the steering column will know what to expect. Ole Trigger will pay dearly for making me at the fingertips and the mercy of the GF this weekend though. Perhaps another high speed run to good ole FLA for some late season red fishing will teach him who's boss. Let me know how you guys like the postings to the tech columns and I'll put the pics in with a narrative after I get them in the way of the IH8MUD way. Yall have an outstanding AMMO day and I'll be back soon.
Dunman
Anybody know where I can get a new speed sensor, instrumentation pod, and TCM? Not sure which I'll need but I went ahead and pulled the dash out to get to the TCM to make sure there weren't any loose connections on the speedo or module. No joy. All nice and tight. I've got pics of the journey to the center of the LC dash. Oh, and the TCM is actually mounted on the firewall to the port side of the steerying column. Got pics of the numbers on my TCM too in case it gets to replacing it. I'm at a loss as to what to do now. Anybody know how to test a hall effect speed sensor?
Here are the pics in the order of disasssembly:
Let me try that again...
Well....I suppose my FNG status is preventing me from uploading more than the three I've already uploaded. Can someone tell me when I can attempt to upload more? I'll go see if I can put it back together for now.
Later.
Dunman,
Why in the world are you removing the TCM? I don't think we have ever had a report of one of them failing, even on the primitive 442 tranny. I read the above responses from Curtis and Sc0 and they did not recommend pulling the TCM, yet here we are.
-B-
Testing hall-effect sensors
These sensors output a square-wave signal which has a frequency proportional to the speed of the tooth wheel rotating in front of the pick-up coil. There should be 3 wires at the sensor: supply voltage, signal and ground.
You will need a digital multimeter which can measure frequency, or an oscilloscope. Multimeter from fluke is cheaper.
All sensors of this type need a 5V supply for them to work. So first measure the 5V supply at the harness (you will need to identify this from your wiring diagram).
To verify if the sensor works will be a lot difficult since you will need the flywheel to be turning. But if you can jack the truck onto jackstands and start it and put it into gear, you can backprobe the sensor signal pin with the multimeter to make sure there is a frequency.
The transmission input speed sensor does not provide the signal for the speedometer, it is rather the output speed sensor. These are usually mounted on top of the rear differential. If your vehicle has ABS, those wheel speed sensors can be used to provide the speedo signal (mostly done on more recent vehicles) and so the speedo will still work with a bad transmission output speed sensor. A 94 vehicle may not have that feature, this is done in the newer cars from about 1996/97.
The VSS on US FZJ80 series is on the transfer case.
(Not my truck or my picture. MikePL's pic)
-B-
Ever had deja vue? As I was putting trigger back together I kept thinking, have I been here before? I did change the evaporator out a couple of years ago but that was a journey to the center of the dash on the starboard side....then it hit me. I had a 95 Corolla about 4 years ago that I aquired by changing a chicks clutch in her Jeep. It had been hit in the port fender pretty hard and needed some work there. One thing though was that the Speedo was intermittent on it and it was doing some of the same silly ass crap and then it hit me, Triggers instrument cluster and the Corrolas (her name was spot because she was black with a new red fender, anyway) was damn near identical in operation and the way it was installed. Anyway, whoever posted the Hall Effect Sensor test, thank you, that was the rattle that brought it back. Just for future reference, you don't have to jack the truck or car up and test the sensor, just pull it out of the tranny and spin it. If your problem is intermittant, put a drill motor on the drive gear. Just don't crank the chuck down on the plastic gear. Anyway, Beowulf is right and I figured it was a long shot but I figured what the hell, find the TCM and pray it has a busted lock on one of the connectors and it has worked its way out. Bwaa haa. I got some good pics of it though so that the next poor soul can see exactly where it belongs and not have to start at the steering column. Oh yeah, well, when I replaced Spots instrument cluster, it started running right and continued for many moons after that till it died a horrible death to a drunk chick rearending her. So, that being said, I think I'll replace the instrument cluster first and see what happens, some how that cluster provides feedback to the system. Call BS if you want, but, it's no coincidence that another Toy built a year later with the same problem after a tramatic life ended up being fine after the cluster was changed out. So follow my logic, we'll see what happens. If it turns out to be the root cause, I'm sure we'll have a run on instrument clusters. Oh, the speed sensor, on Spot, I could not believe that it would be something as bullet proof as an instrument cluster so I chased the sensor first, talk about a pain, I bought three units before I found one that was right due to the different auto trannys in the Corollas...dumbass assumptions I suppose but I had a junk yard available at the time I could just watz into with acres of cars to pick from so I just found a car and pulled the sensor, and then went back and pulled another, and then actually paid attention to what tranny was in the third donor car.... :doh:. Thats why I have so much experience with testing them other than I forgot what voltage was required to excite them. Have an outstanding ARMY day fellow LC'ers.
Dunman.
Dunman,
Think concise problem descriptions if you want to hold our attention and assist you with troubleshooting. If ya just want to yak then try the Chat section.
-B-
Beo,
You really should read it; it's worth it.
Over and out on this thread,
Curtis
Curtis,
I will read it if you will edit his posts and put in some paragraphs. I stared at that glob of words for about 30 seconds. My eyes crossed and my remaining lung started pulsating. Connie won't pull me out of the ICU again this weekend. No way.
-B-
Replace the VSS. Carry a spare if you find one....
Hello fellow Crusher pilots. Being a cheap bastard I decided to pursue this from a cost hierarchy and it has bitten me in the ass. Vehicle Speed Sensor (VSS) is the culprit, and it does a lot of things to the system. CJF hit the nail on the head though when he suggested that there may be multiple demons manifesting themselves at once. Turns out I had a bad wire hold down that caused Trigger to start skipping and the VSS was most assuredly bad causing the ECM and TCM to react accordingly. After digging around the site some more I found that others had experienced the pulsing OD light with a dead Speedo so for those poor souls, here is the fix. Your sensor has gone bad. It could be from gummed up workings or whatever it may be but mine actually twisted the drive shaft of the sensor off into the transmission interface. Once I’m no longer a rookie here I’ll post pics to show the aftermath. It is still possible your cluster is bad but is a long shot, I bought one because it was the cheap route and now I have one with all the indicator lights working but that is it. The replacement part numbers you seek are as follow:
Airtex: 5S4893
Denso: 949973-0021
Toyota: 83181-20040
These are all replacements for your VSS. If you are in a junk yard, look for a 93 to 97 Cruiser or a 91 to 93 Previa. Same part. To my chagrin asking for a Previa part does not reduce the cost. I paid 161.00 for a new one. Landcruiser parts quoted me 219 for new and 100 bucks used. Arm yourself with knowledge and know what to look for. It is a simple screw on design with a stamped shaft for the drive key and has a 3 prong connector with two alignment spades at the bottom with an offset to the right alignment spade on the top. The alignment spades are external to the connector boss. Now that Triggers brain can feel his legs and I fixed the bad ignition wire he runs like a stallion again. If I were an unsavory type I would leave the new instrument cluster in with only 103K on him but I consider 300K a badge of honor so I robbed all the indicator lamps and put the old one back in.
Next order of business, my apologies to Boowulf, when I collaborate via electronic media I allow my thoughts to flow onto the keyboard and thus be viewed as a true collaborative effort. Parsing words is a waste in my profession so forgive me for my lack of empathy to the editors out there. My advice is to not read my posts. I did this entry in Word though and perhaps it is somewhat translatable. For your benefit ;
SCOPE: Exploration of solutions to abnormal transmission shift sequence and poor engine performance.
PURPOSE: To communicate fault isolation flow to using commands (e.g. Landcruiser peeps) to ensure efficient utilization of command (aforementioned Landcruiser peeps) resources.
EXECUTIVE SUMMARY: Multiple anomalies, poor performance and reliability due to unstable engine performance and transmission gear selection during normal operation. Corrected by R&R of VSS unit and Periodic Maintenance (PM) of ignition system.
Have an OUTSTANDING CRUSHER day!!
IYAAYAS
Dunman
One more part number for the VSS: Wells P/N SU6253
