Build 94 80 build
Rocklin, ca
I've been wheeling for both adventure and hard core rock crawling for 18 years and have always wanted a Toyota for the good stock axels, frame and high quality. Unfortunately at 6'1" with Shrek shoulders I don't fit comfortably in any 90s trucks or runners. I spent a couple years in a TJ and then XJ that I custom built. I fell in love with all the interior space wheelbase and weight balance of the SUV chassis. Unfortunately I'm getting old and wanted something quiet and comfortable with doors AC and rubber motor mounts. Something I could wheel and drive around town or camp way out in the desert in comfort. I've always loved the 80 series but wasn't into the price tag until as of late.
After searching for two years I found my project. A 94 FZJ80 clean and completely stock for $2000. High mileage and not running I took a risk and trailered her home.
Congrats with an official Mud solute :flipoff2: So what's up with the not running part?
Does she have the elockers in the axles?
The first thing to go was the running boards to make space for sliders. My plan was to do a 4" lift 3 link front with 35s or 37s until a friend graciously donated to me J springs L shocks and a set of super clean 40th wheels. I installed the springs and a 1" spacer up front and like the height. I'm still planning on 3 linking the front in the near future. I'm really on the fence between 35-37. I'm no stranger to trimming and custom bumpers so clearance is less of a concern than steering getting heavy off road.
You guys running 37s have you noticed a need for hydro assist at 37"? My XJs power steering really struggled in the rocks and deep ruts when I went from 35" to 37". I don't want to do a ton of bracing or work on the steering so any input is greatly appreciated.
Welcome!
Glad to see she's up and running already.
Nice '94 I just got mine mechanically redone myself. Got my triple locked 94 for 1200, not running. It's basically a brand new vehicle now. Just have some small odds and ends now. I feel your joy! Welcome to the group!
Thanks! Dang that's a deal! What was preventing it from running? What all did you do to it?
I did all my own work minus the wiring harness, just didn't have the time. Fixed both mirrors too they were flopping around when I got it. Front bumper was loose from the top two mounting points. I installed a CDL switch added 20hp ;) Still needs a power antenna mast and drivers seat foam.
My buddy has a shop and he did most the work. Except paint and what not. The previous owner let the head gasket go too long. So motor was shot. We did a remanufactured block, rebuild trans, paint, lift, snorkel, rack, rear swing arm for spare. Still have some other stuff I want. It'll take some time, but it'll get there. I did a stubby antenna so I could get rid of it. Works great.
I'm considering a stubby antenna but I like the idea of being able to put it all the way down if there's brush.
Hahaha thanks. I'm happy with it. No they're 94 wheels, just painted. I think you'd be okay with the stubby. It's pretty tough little thing. I'll be off roading it soon. Gotta break in the motor still. Only has about 40 miles on it right now.
I noticed you swapped out the orange lens for clear lens. Where did you get them? They look fantastic.
Busy weekend on the 80. I ordered all the heims DOM tabs and brackets to 3 link the front. Still looking for tires as 345 isn't available in many brands right now. I'm bummed because I wanted to save money on wheels. Oh well guess I'm being forced into 17" beadlocks.
Went to do the brakes and noticed there was a lot of play in the wheel bearings. By an even amount of play (a lot) on both sides I'm thinking the PO didn't set the races all the way in the hubs when he did the wheel bearings. The bearings look new and the grease was fresh. I re packed and set the pre load.
Installed 100 series pads haven't noticed a huge difference in stopping but I'm going for durability and pads were more available for newer vehicles. The pic below shows 100 series next to 80 series pads. The pads fit without modification aside from pulling the backing plates off the inside pads. It did take a bit of re compressing the caliper pistons to have them stay all the way in.
Did ABS delete and LSPV delete. My LSPV was leaking and I had air trapped in the ABS. The fluid that came out of the abs was nasty. The bleeding I did didn't seem to flush anything out of the ABS system. I'm not a fan of ABS, so it was nice to see it go. Sorry I didn't get any progress pics I was frustrated and in a hurry. I'll take finished pics of the deletes.
Finally I installed my OME L shocks what a difference in ride. Went from mush to solid. I think with the slow valving in these shocks I can get away with removing the sway bars. I'm going to start with the front and decide on the rear after. I'd like to leave the rear as long as I don't end up with jerking from side to side like my F250 with rear only.
