Well guys this is my current project, R&R a 1FZ out of a '93 due to rod knock and some tell tale signs of a headgasket. The knock is traced to cylinder 3, won't know more until things are taken apart. The engine was removed from the vehicle without the tranny attached. Reasoning was engine lift height, need an A-frame to gain the necessary clearance for removal of such a long assembly.
I pulled the main harness with the engine, head and intake with exhaust manifolds were still attached as well. I also had to remove the power steering pump from the block as the high pressure side banjo bolt would not come loose and didn't have a big enough wrench for the insert.Had another 4 electrical connectors on the driverside above the starter that were disconnected, kind of a pain with dirt and old foam insulation falling in your face. unbolted the starter and fuel line, vacuum lines. Dropped the tranny/transfer case crossmember a little to unbolt the 2 top tranny bellhousing bolts then re-bolted it back in. Unbolted the 6ea converter bolts from the flexplate, not torqued to death like all the other fasteners... The tranny is sitting on the front sway bar so the truck can be rolled around, weird how Toyota designs things with backup safeties
Had a few problems:
One was the exhaust pipe to manifold connection, besides stripping a nut it was a clearance issue between the bellhousing and the pipes/flanges. When the engine goes back in the pipes will be unbolted from the Cat then bolted in after the engine is in place. The other problem were the steel tranny cooler lines. It seems that these lines have a bracket that secures them to the tranny bellhousing. Unless removed this will make it difficult to remove the engine because it also goes over the engine bellhousing as well.. From the looks of it does the 1FZ have a SAE bellhousing pattern, I ask because it's HUGE! The third problem is probably related to the first two, injector plug cracked for #6 cylinder. Might have broken this when removing... Eh... EVERY BOLT ON THE 1FZ REQUIRES A FLEX HANDLE OR BREAKER BAR! (or impact)
Engine is out and the cruiser now looks to have a 4" lift in the front... I might drop the tranny and transfer case just to go through the wiring harness and the rewrap it as this would be the best time.
Had a few problems:
