Send me a pm with your shipping info
Diesel? I will be interested to know the outcome.
British ex-pat living in the mountains close to the ocean in Spain with a diesel land cruiser? somebody is living it up![]()
Great, thanks guys. The resistance of the connections was good, so I am good to go.
But it seems like the hot radiator pre-warmed the majority of the water or at least that's what I'm telling myself to make me feel better about the situation.Has anyone recently tested how accurate this is on the 93/94's? The first post said it's within a few degrees of the scale listed.
The reason I ask is that I just finished a HG job last night and took it out for a spin. After a 10 minute drive up a steep hill about 1/2 mile from home my temps skyrocketed to about one needle width below the red line. I quickly drove home and the needle didn't rise any more and it never got into the red, it just sat there one needle width below the red. It was only a couple of minutes, and I had the heater on full blast but blowing cold air which I later realized was due to lack of coolant. It turns out that a rad hose popped off and I was about 3.5 gallons low on water so almost bone dry. I filled it up again with tap water and the temps dropped down to the mid point then eventually to cold levels. Being that low on coolant, even only for a few minutes would make me believe that the engine was much hotter than 217 on the scale listed below.
Pegged hot 244°
Top of red is 227°
Bottom of red 217°
Center is approximately 189°
Cold line is 160°
Pegged cold 150°
Any thoughts other than I'm a complete bone head for not double checking the DS rad hose before driving it?
I'm sure the fairly rapid cooling of the motor with cold water wasn't good for it either.But it seems like the hot radiator pre-warmed the majority of the water or at least that's what I'm telling myself to make me feel better about the situation.
If you completely loose coolant the gauge is not accurate.
The sender is reading water temp in the head near the water outlet, as long as there is water present this is a good relative indication of cylinder head temperature but with just air contact reading will be very slow to respond. If you only had 1/2 gallon of coolant driven for more than 30 seconds I garontee your head was overheated.
Keep an eye on it and see what happens. Maybe the head was not yet up to temp yet when the loss happened? All you can do is drive and watch.
