i cant remember what IC chip it is off hand its been 3 ears since i took electronics class some thing like a certin type of AMP IC chip ill look around
Could this kit be used to make the simulated VAF curve for the ECU? It seems like it will be something that needs to monitored and adjusted, and will give limited interaction with the actual ECU.
right now we need something that will exactly invert the voltage.
If you look at the Split Second site, http://www.splitsec.com/spike/Toyota-MKIII-supra/spikeToyotaMKIIISupra.htm
they show an older supra in the the project cars page that spells out the reverse voltage set up. They list a part number PSC1-005 thats shown on the price list
Price List
and the details are on this page:PSC1-005 Data Sheet
at $373. I think this could be used in conjunction with Landtanks Kit.
Hmmm, maybe a supercharger can be tuned right using the stock ecu from a 93-94......
Price List
$373 is pretty steep, and i need to find a laptop with a serial port, but i might do this.
I think this would do the trick. But getting it to imitate the stock AFM could be challenging. Working out a repeatable calibration sequence would be key to getting good results with multiple installs with no CEL.
interesting, reading in the supra forums a cheap approach for upgrading supra mark 3 airflow is to use the VAF from an early lexus v8 which is plug and play on the supra.
I just happen to have one of those![]()
The Supra AFMs are a vortex style unit and not a Vane style. Check compatability on those two. My understanding is that the vortex puts out a varying pulse DC signal.
Semlin, you might contact this guy. That unit should be compatable with our unit and if he would ditch the GM MAF and go with a Toyota sensor like what I did the curves would probably transfer across as well. He would just need to have it in the correct sized chamber which isn't that hard. Between the two groups I think 20 pieces wouldn't be a problem.
it appear the 80s era supra mark 3 had a vaf. the later mk 4 models i looked at when i was doing research before went to the karman vortex. those are the ones where the obd1 ecu can be replaced with an obd2 ecu as a plug and play.
basically mark 3 supra tuners have already done what we are doing. so far I have found that they do it using a vane pressure converter by HKS that is discontinued, using a lexus v8 vaf and using the splitsec set up with a starting map that splitsec created for the mk 3. I need to do a little more research to see if they do it any other way.
That is incorrect. The Lexus AFM is exactly the same technology as the Mk3 Supra AFM. The difference is the air flow is greater and pulse rate is lesser on the Lexus AFM. The difference is the same percentage as changing the injectors from the stock 440cc to 550cc injectors. With both of those in place you can then safely boost your need for fuel (mainly by using bigger turbo) and the stock engine management can correctly manage fuel trim and keep your engine from eating itself.
This is a CHEAP solution for the Mk3 as compared to adding an external fuel management computer or piggyback to the system along with the needed sensors.
...just ask me how I know![]()
