93-94 intake hose
I have a 94 and the intake hose has a raised "grid" pattern on it. A lot of the ones i see in pictures on 93-94 are smooth with out the raised grid pattern. Which one is the correct one for a 94?
When i bought my 94 there was a hand written "to do list" in the FSM. On the list was replace the intake tube. So i am not sure if that was replaced by the PO or if it was something that he intended to do. Which is the correct part for the 94 and any chance they have date stamp on them like some parts?
They usually dry up and crack open. Just remove it and inspect to insure there are no openings in the tube. I believe they are in the neighborhood of around a $100 from Toyota.
This is what you want. Collecting parts for an upcoming tune-up. Not sure the diff between the 93-94 and the later tube, bend and dimensions might be slightly different. The new tube is super pliable, idk why I thought it'd be rigid.
I'm also c
I'm also curious if there is a difference between the 93-94 hoses and later models. A lot of eBay listed hoses just say 92-98..
I'm also c
The 95 to 97 hoses are longer than the 93 to 94's due to the smaller air flow sensor/meter they have. The 91 to 92's are also completely different. If you are looking for a 95-97 aftermarket intake hose, click on the link in my signature.
