92 Overheated today
Ogden, Utah
While running errands, my 92 began to stumble while waiting for the stop light, and I glanced at the gauges and there was the temp right at the red line.:eek: So, I was able to find a park close buy with some shade and popped the hood and coolant was going into the overflow, checked the oil and let her cool down.
Backing up time, I was running the A/C when she began to stumble.
After letting her cool down, I started her back up, and drove home, without the A/C. My little girl did not like that at all:crybaby:.
Turned the A/C back on while driving and after a few miles she started to overheat again. I turned it off, she cooled down alittle.
So, my question is: Is this a thermostat problem?seeing how I have never changed it(2 nd owner) Or is this a lack of coolant?
Any thoughts, inputs or ideas?
Also, my oil pressure gauge was reading low at idle, when she was in the hot zone.
Thanks John
Could be thermostat but lets look at other conditions. How was the coolant level before it overheated and when was it last checked? Do you remember your radiator fan running at any point? How's the condition of the oil (any moisture)? Does the engine stumble when it is cold also? How many miles on the truck?
Hate to be unsphisticated, but have you recently, or ever, flushed the radiator? I had a similar problem with my 62, and replaced everything, hoses, thermostat, water pump, etc. (except the radiator) to no avail. Finally, after cracking the head, I replaced the radiator. Problem solved. Good luck:cheers:Ned
We'll, I've literally replaced everything on my 62 and it still overheats!! :doh:
Well not sure on the level to be honest, it did have a flush about 1 1/2 yrs ago, and everything in orginal ie..fan clutch, thermostat. She has 188,830 miles, I am going to check the level now. I am not sure on the fan running, everything just seemed damn hot. I have never had her overheat like this in years past. Possible clutch though, it makes sense. the temp gauge was normal temp with the a/c on, until about 20 mins in the driving, and damn Riverdale Rd. construction zones, it did have a few stops and restarts inbetween. The oil was changed just a few hundred miles ago with syn. high mileage
Keep the thoughts coming, its narrowing things down.
Thanks John
Order a fan clutch, a thermostat and a radiator cap.
On my 92 a bad radiator cap caused the engine to overflow too much coolant, making it loose enough coolant to not be able to keep up with the Utah heat.
at 188k you are due for the fan clutch. If not from Dan, Mark Miller toyota offers a discount to Wasatch cruisers members. If you are one (I don't remember) I would recomend a coolant flush as well.
Dave
Not to be discouraging, but I have had the same problem since I have owned my 80 and I have replaced everything new oem and still the temp starts creeping towards the red everytime I run the ac.. It is the most anoying problem I have ever had. I hope you nail this and look me up and let me know what you did to fix the problem.
Thanks, I will replace cap and thermostat for now, until $ funds are enough for the fan clutch. I did check the coolant level and she is full. I am going for a recent flush as well. Thanks Again and:cheers:. Will keep posted in this thread after repairs.
John
Thanks Jon, I knew you would chime in sooner or later. Calling today and ordering from CDan.
Done it all and I still have the same problem. Sometimes in the city/trail, sometimes on the highway. On trail in 4low or running up to the high country is the only time without the AC on it will get hot, but I also have a 14"electric fan. I spaced up the rear of the hood the last 2 years with longer bolts and some washers stacked to "shim" it up and give the fans somewhere to push that heat. Right in the cab when you roll down the windows!:mad:
Not running rich/lean, fc, rad/cap, tstat, wp.....its a heat gremlin:bang:
My 91 had the same problem, I replaced radiator, thermostat, water pump, fan clutch, turned out it was my cats were stuffed up.
I just ordered from CDan yesterday, I will post as soon as I get them installed and a test run. I did not get the fan clutch, yet.
My cats have been removed and a single aftermarket installed, about 1 1/2 yrs ago, and just recently replaced the O2 sensors as well. The muffler is a magnaflow and she purrs pretty.
I am curious why this just started to happen though. I have ran the A/C many times in yrs past and no problems. Tryung the cheap parts first and going from there.
Any other thoughts or ideas, please reply.:cheers:
John
Single most overlooked part of the cooling system. Lifespan of around 100K miles, no accurate diagnotic, failure can happen in 3 different ways.
Replace with OEM.
Is your fan shroud intact?
Is the space between the condenser coil and radiator coil free and clear of debris? This space NEEDS to be cleaned if you go in water at all. I was AMAZED at the amount of crap that came out from a simple garden hose.
I agree with Jon,
The later 80 series have the upgradeable oil change out fan clutches, I would consider using the 93-95 model if it will fit, I put mine on 5 years ago so it was not an option. It would be nice to be able to fine tune the oil to a different operating temperature.
Pulling the radiator when you change out the fan clutch makes the clutch a lot easier to replace. Plus it would give you the easy acess to clean out the back side of the ac condensor and power flush the radiator. I understand the budget but a 3FE will blow a headgasket if it overheats. (from experience) save you pennies or switch the Keystone and get it done.
Dave
