Sounds like a great idea!
That was pure sarcasm. Putting wheels on your cruiser that weren't designed for its heavy loading is a bad/unsafe.
Doing it by adding spacers is even worse.
If you need a cheap wheel for your cruiser, the steel spare for current gen 4runner works just fine.
What bolt pattern wheels do you have that you want to use? IMO, it makes a lot more sense just to buy some wheels that actually fit and use the tires you've got. Then sell the old wheels separately.
There may be some spacers that adapt from 6-8 lug, but I don't think there are any 6-5 out there. Either way, i think correct wheels is the way to go.
Well, I think you meant to say Semi-float rear axle not full float...as the full float is the stronger design. That would be one good reason not to use spacers/adapters or overly backspaced wheels. I'm sure some people do it and haven't had trouble, but from and engineering standpoint it's not sound to add that additional leverage. I've seen too many walked out semi-floats with oversized tires or adapted/spaced wheels. But it's your junk, due what you will, just make sure if it causes you to wreck that you sacrifice your cruiser and spare others around you.
If you have to use adaptors, these are the best I have ever used:
Wheel Adapters, Wheel Spacers, Hub Rings for your car! | Motorsport Tech
Stahl Steel, Lenny is the Owner
Machined Billet Steel, hub centric on both sides, any bolt configuration.
Just specify the application with info on the axle and the PCD info on your new wheels.
That way they are made exactly for your application and not universal. You don't want the
weight riding on the studs alone.
I will agree with others in saying that cheap import aluminum non hub centric adaptors are scary at best
Especially when using large or heavy wheels. I have never personally had a problem with an adaptor breaking
even the cheap ones, but you see plenty of horror story's online. Basically, You get what you pay for.
@EffJayAte the drum brake rear Fj80 is a semi-float. Meanining the axle shaft is semi-suspended between the differential side gear and the bearing pressed around the end. It is held in place using a C-clip which holds diff side of the axle shaft in place, your tire bolts directly to the axle shaft. This type of axle suffers from more deflection of the axle shaft under power which can cause the C-clip to wear and eventually fall off or just sheer off. The full float axle is built like a front axle where it has spindles which have a hub bolted onto it. Then the axle shaft slides into and is supported by the diff side gear and then bolts to the face of the hub similar to the purpose of the drive flange up front. If you break a full float axle or walk out a full float axle shaft your tire stays on the rig. If you break lose the C-clip on a semi-float the axle walks out of the axle housing and you either stop before your axle shaft and tire go sailing past you, or you watch in awe as your wobbling tire and axle shaft pass you and you wreck your truck. It's not something you have a choice in. But, in all fairness I haven't seen an 80 walk a shaft or lose a semi-floater. Just a bunch of American junk and a couple tacos.
No, the front end is just a front end...the rear end that uses a spindle and hub is a full float. I'm sure you could use the adapters. But why? Are your tires on a funky diameter wheel like a 16.5" or something?
I understand wanting to use the tires and wheels. But if the tires aren't for a odd sized wheel it would make more sense to buy a proper wheel than spend $600+ for an adapter. My 5 steel custom back spaced rock crusher 17" wheels cost $495 shipped to my door plus mounting and balancing.
You could probably sell the bare wheels.
