Alcon,
I have a problem with the 3FE engine starter circuit system. I can operate the vehicle for approximately 30 minutes. If/when I shut down I have to wait for approximately 1 1/2 hours before the starter will engage to start the engine. I do a click but no starter rotation. The starter has been mechanically looked over and tested. It tests fine. All the grounds are good. I even connected a ground directly to the starter.
I have went through the entire ignition/start circuit system. From replacing the battery to all fuses. It seems like a relay but I cannot find a bad relay. I have traced all wires. I have not yet tried to jump the starter when I get a no crank.
After the wait I can start normal and itt will run. Until it heats up again.
I have noticed that if I turn it off and a minute or so later I can start, crank, and run.
It has me baffled at this point.
Any help would be greatly appreciated. Also a schematic of sorts would help aas well.
Thanks Ed
Thanks Ed
