92 FJ80 Start Problems
I had same issue on my truck click but no start sometimes it would crank sometimes just a click and if i played with the switch after a few turns it would sometimes start i read here to schange contacts and plunger and i did works great for past year. They also sugested tapping on the starter with a hammer when i cant start the truck and then try to start it if this works then most likely is your contatcs/solenoid even thought u had it rebuilt try tapping it and if it works u can look into the contacts/solenid make sure u get OME parts at that point.
wire harness check
if the truck is turning over... but not starting...
My fzj80 had same problem. (thought it was fuelpump or relay... etc)
I found that the wire harness that goes from inside to the outside of the cabin is rubbing and shorting out the fuel pump. The hole where the wires pass through is in the back seat driver side floor under the carpet. (the rubber ring had fallen out allowing wires to contact metal body)
to test.. when truck wont start.. just reach under the truck and try wiggling the wire harness as it comes out of the floor as truck is turned over.
hope this helps...
Steve
I'm going through a very similar problem.
I just rebuilt my starter and no help. My current list of possible culprits is:
1) bad ground path
2) bad fuseable links
3) bad ignition swith
I'm going to hot wire my starter tomorrow and see if it works that way.
I'm going to have to search this NSS thing.
