92 80 Clicking front end
Western SD
Hello all,
My 92 80 has 220 K miles and the front end is clicking....I know it needs the front end redone. No biggie. The dealer wants $1100 in parts not including bearings. Seems like alot. But if I have to.
I read in the FAQ that you could switch the birfs from left to right and all is good. Is this true??? Seems to good to be.
For the 92 is there any other years that are the same. Mini Truck maybe? Trying to save what I can, when I can.
John
85 FJ 60
92 FJ 80
TLCA 6192
The 80s have their own birfs...no swapping with other models. Within the 80s, you can swap 91-94 or 95 (not sure on that cutoff). If you use later than that you have to replace the drive flanges at the same time as the later birds have longer splines.
You can swap them side to side, but not going to stop clicking if you have that high of mileage...you are gambling. I would say you dealer has quoted you list pricing. I would check with cruiserdan on here to see if you can get a deal on that gear and supply the parts yourself.
Without birfields the parts should be around $200-250 total. OEM Toyota birfs are indeed high dollar, so I would think your total should be close to that estimate with birfs and tax.
Alternatively, you can do the work yourself and save a LOT of labor. If you thought that price was high for parts...labor will be more. It is an dirty and time consuming effort, not really that hard.
Longfields are not recommended for DD use. There were some sold by Slee and a few folks found some on Ebay that were satisfactory. Otherwise, you live with the click or buy new.
I am sure others can chime in with their sources. I use mine primarily on the trail so Longfields were perfect for me.
Why arn't Longfields recommended for DD use?
Chromoly is the issue from my understanding. I would think anything like a newfield or other heat treated OEM spec material would be more attractive for DD.
I had the clicking also on my 92' with 210K. Finally wouldn't go unless diff lock button pushed (locks front and rear diffs). It's a "path of least resistance" deal and stripped gears were easiest to turn.
Check what the dealer will provide for $1100? Will most likely NOT include the birfields and flanges!
Looked up birfield costs:
Dealer: $650
Cruiser parts: $250
Man-e-fre: $200
I did Cruiserparts.net, should be in tomorrow. Bought +94 birf and flange for PS that was totally stripped out, bought flange only (-94) for DS. Like Dan said it's a dirty job, but I'm really enjoying it!
Also bought Man-e-fre's rebuild kits (2 knuckle bearings, 2 hub/axle bearings, all the seals) for $180.
Saved so much money (like how the wife shops), bought OME lift kit (springs, shocks, etc.) for $720. Into it for about $1,600, but know the job will be right.
Grease is another deal (search the site). Decided on Amsoil GHD with moly for birf and steering knuckle, and Amsoil MP (WITHOUT MOLY) for hub/axle bearings. While there bought their better 75/90 oil for diff.
Good luck and keep us posted.
BURBIS
Cv Unlimiteds web site seems to imply that they make products similiar to longfields. That is they are less hard but more flexible....so they will not shatter as easy.
I really dont want to get used ones.
BURBIS said;
I didn't think that the clicking was related to something stripped out. I thought it was from worn Birfs, am I incorrect or confused.
John
85 FJ 60
92 FJ 80
TLCA 6192
Oh yeah.
The dealer wanted $1100 for the 2 birf's and the gasket kit. No flanges and no bearings.
Whenever I have done the front axle on the 60 or my old 40 I did the whole thing wheel bearings, knuckle seals, bearings etc... so 1100 becomes closer to 1500 or so.
John
85 FJ 60
92 FJ 80
TLCA 6192
Path of least resistance was the reason it wouldn't go on mine. Nothing to do with your clicking.
"$1100 for the 2 birf's and the gasket kit" Whose your dealer?
Mine said $650 each birfield + $50 each flange. I'd have been up to $1,400 to replace both sides. + $200 for the rebuild kit. + $200 miscellaneous = $1,800.
Don't get confused,
the clicking you are getting is the birfs. The no power unless I am in cdl locked mode is a stripped drive flange in the frt end. two different demons.
I just picked up a rebuild kit from Kurt at cruiseroutfitters a few weeks ago and installed, I am lazy and jsut replaced all the bearings and races in the frt end. He had some kits for the 80 on clearance, might be worth looking.
FWIW I would open up the rear end and chage out the semi float outer bearing as well, Mine is a 92 with 217k now. The rae bearings had a lot of play in them once pulled out.
Dave
Hi all,
The dealer is my local Toyota Dealer in Rapid City. SD. They have always treated me well pricing wise.
But I am looking for anohter altenative. I see that Man a Fre has some aftermarket Made in Japan birfields for $270 or so each Touted as being for a DD. Has anybody ever used these. I will try Kurt at Cruiser outfittrers also.
Regardless of price I must be getting good quality.
I am learning a lot.
John
85 FJ 60
92 FJ 80
TLCA 6192
