91 Shifting issue
Update. Still having trouble diagnosing
Issue
Front birf drive flanges good
Will drive in 4 low not in high when I do go in 4low the truck will drop down about 3 4 inches and raise up?
I took both drive trains off and if I put it in park easy to push ?
Any help would be great
Thanks
OK, so you have a '91 FJ80 that's been sitting. Are you located in the US? A US/Canada spec '91 should have a CDL button on the dash, that locks the center diff providing 50/50 power distribution to the front and rear axles. As you don't have a CDL button, putting the transfer case in low range will accomplish the same thing, in that it automatically locks the CDL. You should see a dash light confirming the CDL is locked.
So with the transfer case in low range, have someone stand on the brake and start feeding in gas in an attempt to overcome the brakes and drive forward. SAFELY, look under the truck and confirm if one or both driveshafts are spinning. If only the front or the rear is spinning, that's the side your problem lies. The power will flow to the wheel with the least resistance, so if you have a stripped driveplate on the front that corner will have the axle spinning in the hub, but the driveplate teeth aren't there to transfer power to the wheel.
Do the test, and report back, the fix will flow from a proper diagnoses of the problem.
Is this a US spec truck?
Does the truck try and move? Or are both driveshafts spinning and no power is getting to the wheels?
Can you expand on what you typed above, that it would drive in L but not in H, and when in L it would "drop down about 3 4 inches and raise up", what does this mean exactly? Is the truck driveable in certain conditions?
Have you checked the trans fluid level with the engine running, after rowing through all the gears slowly, and then left in P or N while you check the trans dipstick? Is there enough fluid?
Yes US spec
It is drivable in 4 low while in 4 high it won't shift into any gear I did check fluid
But not while running !?
As far as the 3-4 inch drop when I put it onto drive in 4 low it raises up and then it will drop back down feels like hydrolic ?
Trans fluid is checked with the engine running, row the shifter through all the gears and back to P, then check the level (preferably when the trans fluid is hot).
So you can drive it and it will shift gears while in low range?
A video would be very helpful in seeing what you're talking about with the raising and lowering bit, I'm not following what you're experiencing.
I’m thinking his front shocks are “toes up” and vehicle is bottomed out on shocks, therefore when in 4lo the torque is making the rear “grab” better, and front end starts picking up. I believe I know what he’s trying to explain there. Hopefully you can decipher my explanation. Lol:flipoff2:
With my above attempt to decode op’s “Raising up 3-4” is probably confusing as heck..... it did make me think..... if the torque is coming from the rear so profoundly, it would lead me to believe the front is where the issue is.
Rumi- where are you located? East Coast? West Coast?
Yes that's would be great!
It's been sitting since 2005 put a used tank and fuel pump to get it started.
That sounds like the squat move u explained I'll take a video tomorrow.
Yes truck move F and R in Low!
I interpret this to mean; when the CDL is locked, it drives normally? If you want to drive it in high range, shift low range to lock, remove the Diff fuse, shift high range and drive.
... Definitely the front spinning rear not spinning . ...
I interpret this to mean; when the CDL is unlocked and attempt is made to drive, the front drive shaft turns without driving the rig?
... It does shift gears in low and drives in 4 L.
The above adds up to something broken in the front axle, could be gears, axle, birf, but when broken, those parts almost always make significant noise and/or affect steering. With no report of that, leaves birf and/or drive plate splines, can strip with little if any noise or other effect.
Ok so mixelplix came an looked at rig
And explained better terms to me!
So 4 high front drive shaft spins noise coming from pumpkin center diff engaged pumpkin gets louder !
Hope that's a better explanation
Didn't know I had the diff button.
I would say you need to pop the front diff cover off and inspect. I imagine the gears let go.
I'm thinking diff too, but here's my best description:
4wd high: no vehicle movement, front driveshaft spins rear does not, grinding noise from the front diff, axle stubs don't move.
Here's a weird one...
4wd high cdl light on: same exact thing as above, louder grind, truck still doesn't move.
4wd low: truck lurches and moves, cdl light comes on.
So unless I'm mistaken we have a power disconnect at the front diff. Based on the noise I think the pinion is rounded out. The only unusual thing is the truck won't move in 4high when the cdl light is on. I'm guessing the slip coupling isn't engaging in the transfer case - but if that's true, why does the light come on?
Regardless it's a pretty nice truck, and in decent shape.
Someone else chime in with suggestions, if there's anything I may have missed.
@Rumi At this point, unless someone has any other suggestions I would pull the cover in the axle housing (the front axle housing has an inspection cover, right? If so it would be on the front of the front axle housing.. the round part referred to as a pumpkin) and post some pictures of what you find.
companion flange toast?
Good idea. I didn't check.
@Rumi the companion flange is at the front end of the driveshaft and four bolts go through it. The part that's attached to the diff is what you're concerned about.
I can't really remember how you remove it from the pinion in the front diff...
