91 runner with gas leaking from above gas tank
so i went out to start the runner and i started up fine but ran kinda ruff and then gas started spuen out above the tank which i couldnt c f.,k all where it was comen from any ideas the under carriage is pretty rusty so im guessen just a cracked fuel line. What do you guys think. i tryied to take off the tank but it had rusty bolts which i will have to chisel off to get to the top of the tank.
There is an access panel under the seat in 2nd gens, but I don't think it's big enough to fix this. Resign yourself that the tank has to come down, your high pressure fuel line has sprung a leak. It's actually common, I had to do the job on my son's old Corolla last summer, it SUCKED. It is probably the bracket that holds the fuel pump in the tank, it has a big flange that bolts to the top of the tank. The high pressure line is steel as it comes out of this bracket, bends 90degrees, then attaches to a stiff hose with a flare fitting. This part usually rusts out right where it exits the top of the tank, I believe it's about $100 to replace, is probable a dealer-only part. Here's what it looks like:
The second picture shows where it isually rusts thru, right at the bend.
It could also be the fuel line that is bolted to the frame rail. If it were me and I were going to all that trouble, I would replace both of them anyway.
Besides the usual tools, you will need flare wrences, lots of PB Blaster, a floor jack to raise & lower the tank, and a garage with plenty of ventilation.
thanks
ok kewl thanks guys ill check it outfrom the top first then take the tank off later if needed ill let ya kno what goes down.
the assembly will not fit out of the access hole.call me redneck but I marked a section off uner the seat & took a jig saw to make an access hole.cut out on 3 sides,fold it over then fold it back when done.one day i'm gonna scrw a removable plate over it.only thing is if the tank has rust in it your gonna have to pull it anyway.good luck either way
