Make it easy on yourself. Free loaner fuel gauge kit at Autozone. Remove the cold start injector line from the fuel rail and tap into there for the test. The fuel rail is the best place that you can accurately test the fuel pressure required for the injectors. The gauge will be inline so if you can have someone start the vehicle while you are observing the pressure readings that is best.
With the fuel pump bypassed through the diagnostic box, turn the key on, crank the engine and check fuel pressure. FSM states 37 to 46 psi. Results from this test need to be obtained during your no start situation.
Edited: key on, to crank engine. Fuel pump will not come on until engine is cranked over and AFM door is opened
