91 FJ80 will not start
Manitoba, Canada
My 1991 Fj80 was sitting for about 5 days, then went to start it and it would not start. Have traced the problem to the fuel pump. I have checked the connector and was gettin about 10 volts to the fuel pump. Replaced fuel pump and it still wont work. Tryed hooking fuel pump up to external 12 volts and works fine. But when i put it into the circuit it will not operate. Have tryed using a different ground and also tryed jumping the positive 10 volts across the connector and straight to the fuel pump and it still wont go. I am stumped... Does the fuel pump need 12 volts to operate? Any help to this problem would be greatly appreciated! Thanks in adavace
-Andrew
Get a multimeter and Ohm out the wires to your fuel pump should be around 0.0 - 1 Ohm for each wire. I have seen wires corroded or burnt up (at the connector) that would allow the voltage through (10volts at pump) but not allow the amperage through (pump won't run) most likely at the connector or fuse box. My First guess would be the connector at the fuel pump side look at each connection in connector for signs of overheating or corrosion same at fuse and relay connector.
Do you know what type of amperage the pump should be drawing? Thanks
