91 3fe motor mount replacement
Socal
It's my first post.. sup everybody.
I've been going through my newly acquired rig and been using mud as a good reference guide.. but need some help.
1. Do I have to remove any exhaust component to wiggle the engine around for the.motor mounts. Or anything else I have to unbolt or remove or watch out for?
2. I have play in the transfer case to the rear axle..is that normal?
1. I don't know, but I bet you could find it in the manual. Offroad 80's • Factory Manual Downloads
2. A little is normal, but if you hear a clank when you put it in drive the T-case output shaft could be worn. Mine is also worn, so let me know how easy it is to change!
Thanks dude.. I think the motor mounts are causing vibration especially since the drivers side is missing a bolt
to replace motor mounts they both have to be unbolted, motor lifted a few inches (dont lift under oilpan)
Was replacing my mounts on a 92 3fe this weekend.
So, I lifted under the oil pan after reading a few threads saying you could only to slightly bend the front of the pan inward. Bad news. Started her up for approx 10 seconds and there’s now a rattle from that spot where the bend is. What’s the do you suspect it is and what is the fix.
