- Thread starter
- #21
That tank basically fits under the central rear passengers feet/arse... inside the frame rail, ahead of the rear axle and beside the tailshaft obviously..... I have one in a 2h powered 60.... there should also be a couple of other brackets... I'd have to have a look to be more specific..... the PO on mine cut a hole through the left rear guard and added another fuel cap there, but it's as ugly as a hat ful of arseholes with the good ones picked out... just a round generic cap sticking well proud of the guard. If you're any good at panel work maybe a second original cap/flap etc in the left rear quarter or a dual throat thing under the existing cap.... I do believe it makes for a fairly slow fill on the LR tank though if you're coming from the factory filler position.....
If you have the chance, I'd love to see a pic or two of you tank installed. I had a look underneath where you were talking about but I just can't get my head around the mounting positions. None of the existing bolt holes seem to be in the right positions.
It did come with a couple of 'U' bolts and a piece of rectangle section, so I assume that crosses the chassis rails and the 'U' bolts are used around that.
