Build '88 Italian Spec BJ 73
So I removed the levers , I covered the entrance with newspaper and tape to prevent the entry of foreign bodies
After removing a mess of components I put the " baby " on a cart to take him for a walk !
Oil leak from rear crankshaft seal
Then disassembling the motor flange / gearbox
This is the last main bearing that serves as the seat of the oil seal
New seal ready for mounting
I enjoyed it a bit ' with the sealer and then mount the motor / gearbox flange
The red circle is the O-ring of ' camshaft seat
These pieces were loaded onto a trolley and washed with a pressure washer and a very powerful cleanser
All clean!
Sand blasted...
And painted whit 2K matt black
Then I worked on the gearbox, which showed no malfunction , but had a leak in the rear seal of the transfer , the speedometer gear device , but with the words I did not know better express . Better Photos !!
Note the sludge present on the walls !!! I removed the lid to replace the oil seal shift shaft / gear , there was no spill , made in advance because I had everything taken apart !
Tachometer gear whit relative seals
6x18 and 6x19 are the gear/ratio of the Vm'd BJ 73
This is the seals and the OEM number
Changed the Thermostatic oil valve, inserted in the oil filter housing
This one
The problem with this is that by the time you get tired , remaining open and the oil does not reach the right temperature .
In Bj 73 VM is present a heat exchanger for the engine oil , in bottom of the radiator coolant . Remaining open , the oil is always running and does not heat well !
I put a K probe after the turbo ... I do not know if I did well , but did not want to puncture the exhaust manifolds ... I soldered a tube of stainless steel threaded inside to accommodate the probe
This is my EGT setup, 12 € probe+3 digit display, from china friend:)
I placed the probe in the first piece of exhaust pipe , just after the turbo down- pipe , because I did not want to drill the exhaust manifold cast iron !
I do not know if it's right:rolleyes: I was afraid of some fracture of cast iron , or impurities that fall in the turbo or the breaking of the probe and subsequent fall in turbo:bang:
Someone has experience about how to behave when the probe is post turbo ? Temperatures pre turbo should be higher ? I have heard different opinions about
What tyres do you have on the standard rims?
Do you know the part number of the oil thermostat?
Do you have more photos of the flywheel? How is adapted to the Toyota clutch? Do you know the size of the clutch?
In these photos there are Ziarelli Cruiser 255/75-16 on stock rims, today i have Toyo open country mt 235/85-16.
In these photo, you can see the part number of oil thermo valve.
Made in Japan, aftermarket Exedy clutch.
275 mm disc, 10 cave.
This is the flywheel, it's made "ad hoc" to bolt on VM motor and the original Aisin toyota clutch of the 80's J6 and J7(heavy duty, not LJ)
Mounting plate VM/H55F
Flywheel mounted
VMOTORI is a brand now owned by jeep.
without using Wikipedia, it was a partnership between German Technology and Italian Technology many years ago. They also make much larger diesel engines including engines for ships? I may be wrong as I'm shooting the s*** from memory.
These engines have been used on a myriad of cars and yes more recently on Jeeps- except the Grand Cherokee in italy. In the past some Defenders had Vmotori engines. The NA Jeep Liberty that are CRD have VMOTORI engines; chrysler bought these engines and tried to over complicate matters so they normally fail. They can be hit or miss; however they are widely used in Europe and very popular in Italy and seem well respected.
ciao, bellissima LC, dove sei? Mi fa piacere leggere le tue descrizioni in Italiano.
Ciao decoco, infatti sono in Italia, in Puglia per la precisione. Grazie per l'auto, che viene curata personalmente in ogni aspetto!
Per quanto riguarda le descrizioni in Italiano è perchè queste sono anche postate nel forum "Registro Land Cruiser Italia", il migliore punto di riferimento in merito ai Toyota nel nostro paese!
This is the story
LA NOSTRA STORIA - VM Motori
Ciao, year of construction 1987, it's a only mechanical version HD(no electric hubs, no vacuum engage for 4x4, nothing...) made in Portugal with Italian motor VM, minor electric parts are from Portugal and Spain, and all the other parts are Toyota.
I don't have fender flares, don't know...but in this forum there are many example!
Use the search function on forum, is the biggest info archive in world!;)
