craigslist 87 Toyota Sunrader
ace10
Another one bites the dust!
Rural NoVA
No affiliation
1987 toyota sunrader
VIN: Jt4rn63b3h0127880
condition: excellent
cylinders: 4 cylinders
drive: 4wd
fuel: gas
odometer: 85032
paint color: white
rv type: class C
size / dimensions: 18ft
title status: clean
transmission: manual
SUPER RARE TOYOTA SUNRADER!!
Sunrader made only an estimate 25-30 of these 4×4 fiberglass overhead / passthrough campers from 1985-88. This is a factory Turbo (22RTE), of which they made maybe 4 ever. This one does have the upgraded 6 lug rear axle.
Year: 1987 TOYOTA SUNRADER
🏁RUNS LIKE NEW ,GOOD POWER🏁
#MATCHING NUMBERS ENGINE ✅
Maker/Trim/Model: Sunrader
Length: 18FT
Odometer: 85032
Drivetrain: 22RTE TURBOCHARGED EFI
5 SPEED MANUAL TRANSMISSION
DUALLY TIRES
4x4
TRUCK FACTORY OPTIONS ✏
Air conditioning
Power steering
Power brakes /front disc rotors
Bucket seats
Cruise control
More Details !!
CLEAN CALIFORNIA TITLE
CLEAN CARFAX!
ORIGINAL MILES
CALIFORNIA RV/TRUCK
SMOG CHECK PASS TODAY 02/24/2020
CURRENTLY REGISTERED UNTIL JULY 2020
I have owned this Sunrader for 2 YEARS
18’ model
Extraordinarily rare–one of approximately 4 Sunrader built with factory 4 wheel drive
22RTE TURBOCHARGED 5 SPEED MANUAL TRANSMISSION
26 GALLONS GASOLINE TANK !
CB radio cobra
It was completely stock and unmodified at that time. I bought it from the second owner who had owned for days 😎MY BROTHER )
NEW PARTS AND SERVICE ENGINE
New water pump Toyota oem
New distriburator cap and rotor
New valve cover gasket
New thermostat oem
New ngk Sparkplugs
New 3 belts
New antifreezer
New front crank seal oem
New oil pump seal
New K&N air filter
New oil change with Toyota oem filter
New sparkplugs wires
NEW CHARGING SYSTEM/AIR CONDITIONING
AC RECHARGED/new service
new DENSO air condition compressor
New DENSO heavy duty alternator HO
1 new interstate deep cycle battery 550cca
1new interstate mt 26R
NEW TIRES AND WHEELS
7 BF GOODRICH ALL TERRAIN KO2
235/75/15
NEW REAR 4 /15” custom wheels by Custom & Commercial Wheel (Bloomington, CA—the only place in the country that builds custom Toyota wheels in this size and the OEM supplier for Toyota RV duallys in the 80s!) ($1200)
NEW INSTALLATION/UPGRADE
FACTORY 1 TON REAR DIFFERENTIAL AXLE DUALLY!!!
NEW SUSPENSION PARTS
NEW Front Bilstein #24-184830
NEW rear Bilstein #24-002585
NEW REAR AIR BAGS AIR LIFT 57113 LOAD LIFTER 5000 series rear leaf spring leveling kit
AIR LIFT BRAIDED AIR LINE #52300
DAYSTAR air bag cradle 4WD
FUEL TANK (RARE )26 GALLONS
NEW OEM FUEL PUMP
NEW SENDING UNIT
NEW PARTS /SERVICE TRANSMISIÓN BRAKES CLUTCH AND FRONT AND BACK DIFFERENTIAL!!
ALL FLUIDS ARE NEW ✅
differential front and back✅
Transmission ✅
Clutch ✅
Engine ✅
New clutch slave hcylinder oem
New rear brakes shoes
New wheel cylinder
New seals and gasket rear end
FRONT BRAKES
new rotors
New brake pads
New front sway bar bushing
INTERIOR DETAILS UPGRADES
LED LIGHTS
2 MAXXAIR 10 speed 14” 12v 04000k
4 SPEAKERS PIONNER/factory cassette radio
EXTERIOR DETAILS UPGRADES
ALL WINDOWS REMOVE AND RESEAL
NEW ROOF FAN AND VENTS NEW AND RESEAL
LED RUNNING LIGHT
LED STOP LIGHT
ALL SCREWS ARE NEW STAINLESS STEEL
INTERIOR APPLIANCES
NEW SELF PRIMING JABSCO
water system pump #31395
Self priming,low noise,corrosion resistance
➖Stove and oven BY WEDGEWOOD
4 burners and oven STAINLESS STEEL
➖Fridge by DOMETIC RM2400
Gas and electric
➖SINK STAINLESS STEEL
➖POWER CONVERTER SERIES 6300a
Model6325
🟢features automatic relay to switch between the converter and Rv battery for 12 volts DC power for RV
25 amp with battery charger
Input 3.9 amps 110 vac 60hz
Output 25amps 3amp charging
➖HYDRO FLAME
ELECTRIC SPARK SWITCH
➖EMERSON HEATHER CONTROL
EVERYTHING WORKS PERFECT !!
UNMOLESTED WIRE HARNESS!!
NO HOLES OR RIPS ON CAB!!
NEVER BEEN REPAINT!!
FACTORY PAINT!!
NO LEAKS!!
NO RUST!!
NO PETS INSIDE OR SMOKE!!
NO LIVING IN RV!!
SOLID CALIFORNIA TOYOTA RV!!
99% FACTORY
IMPERFECTIONS
rock chips on hood with oxidation patina 😎
1 Rock chip windshield
Some verysmall dings in front body
Some old very small touch up
SOME WATER DAMAGE FROM
WINDOWS AND ROOF FAN NOT SEALING PROPERLY
(Not bad at all)
I think that covers most of it; I’m happy to answer questions from seriously interested potential buyers.
SOLD AS IS
NO WARRANTY OF ANY TYPE
THANKS FOR LOOKING MY ITEM
