85 distributor in a 77
Bountiful, Utah
85 distributor in a 77 UPDATE!!!
I just got an 85 Ignitor and Distributor for my 77. I know I will need to dent or replace the side cover but what I don't know is what all is involved wiring this bad biy up?
Any tips or is it so easy that I should not even be asking.
Thanks in advance
Daniel Tubbs
It's one or 2 wire hookup, you need an FSM for the 85 to wire it in, not sure if the cover can be dented that much.......I have the same thing in my 45, guess I could look at the wire color, but if I don't know what year FJ60 mine was
Butch
you will need the side cover for the engine with the dent in it. Also, it is as easy as can be for wiring...
the coil/ignitor plugs into the distributor with factory connections. All you need to do is connect the black with yellow stripe wire from your wiring harness to the + side of the coil. thats all it took to make mine work.
Please look at my other post "ignitor box" from earlier explaining the swap. I will bump it for you.
I have done this several times, and just got done doing an 86 setup on my 77.
You need the side cover DONT try to dent your stock one. There is a perfectly round indentation on the side cover that will necessitate your larger distributor.
Otherwise, as you know it will not fit.
Ragman
Whatever it's worth... I had a large body FJ60 distributor in my 79 for a while and it fit fine. My side cover doesn't have the indentation for it. I'm not sure why mine is different from everyone else's. :confused:
Either A. It was an earlier distributor or B. your side cover was modified or C. The dizzy was modified.
If you have the stock side cover on, the bigger late FJ60 distributors will not slide down and install completely without hitting the side cover.
It just won't work. Jason, if you had a picture to post, that would speak volumes as to what you have going on. (although you have a 79...im not sure iv there is any physical difference between your 2F and a 78 other than head??)
Later,
Ragman
Sorry no pictures. It's a stock 79 FJ40 with a small distributor. I sent my distributor out to Jim C. to get rebuilt, so I borrowed a large body distributor from a friend who had a spare FJ60 engine in his garage. It was close to the side cover, but it fit. :confused: There may be something wierd about the 79 - I dunno.
It was a nice swap since the plug was the same. Just bolted it in and plugged it in.
also on the fj60 ignitor there will be 2 green plugs, one is for the tach on the 60 and you can use this for a tach in your 40. the other is the one that get juice. I forget which is which but ya got a 50/50 chance :)
the wiring is the simple part, getting the old cork off the block for the new gasket is the hard part ;)
also, when swaping the side cover, take everything off thats in the way, the dizzy, the oil filter, the plug wires ect ect, just makes life easier.
its a great upgrade!
People have dented older style covers and run "big cap distributors." You CAN do it. Not the best solution.
I extended the harness between the coil/ignitor and hookep up an ign. switched positive. I had an FJ 60 to look at so that was easy. Nothing too difficult.
Oh...and unplug the battery... ;)
how do i know this? well, the permanent scar on my finger....
FACT: ratchet/socket + Titanium wedding ring + contact with the starter lead (right close there) = zap and welding to your finger...I've got cool burn marks on my ring...
:rolleyes:
just fyi
I have done the cork thing, if my head wasn't shaved I would have torn my hair out.
I am going to get a later sidecover and do it that way.
The wiring sounds like cake.
Thanks again everyone. I will update when I finish.
Ok, another dumb question.
I currently have a Weber.
I am going to go Propane in a few months.
I have 2 vacuum ports on the 60 distributor.
Where the heck do I put them?
I know where to put one, but not the other.
Thanks, Daniel Tubbs
Ok, so today I cranked it over to attempt to start it.
I have spark from the coil, does this mean I have a working ignitor?
It will not start but number one on the rotor seems to line up with the ball on the flywheel.
Could I be off 180 degrees?
Could the ignitor still not be connected correctly even though I am getting excellent spark from the coil?
I hate this but have most of the weekend to figure it out.
i seem to recall that one of the emissions valves needs to be kept to properly advance/retard the distibuter...can someone elaborate, since i'll be doing this to the 45 soon.
on my 77 2f(de-smoged) with a Aisin 1 barel, i just hooked the advance up to the vac off the carb(just like it was with the non US dizzy) works great.
If your running the later dizzy with a motor with stock emission I don't know what you would need to do.
John
where is the vac diaphram on the dizzy pointing? I recall it being at 5 o'clock if looking down on it from the top(standing on the PS)
I can snap some pics of my 77 with the fj60 dizzy in it.
But it was a very simple electical hook up.......even I got it right ;)
John
John
A Picture would be great!
I have the diaphram at 5 o'clock and it looks to be on timing wise, it tried to start but now it is only cranking.
