85 4x4 converted to 22R
My 85 is all stock except it has been replaced with a 22R...It does not have a snorkel as the exhaust manifold has the re sensor thing on it..What is my predicament as far as passing emissions and resale?
I am calling it a snorkel..Comes out of the air filter assembly?,,Y'all know what i mean..I am worried i may not pass emissions with this set up?....Any feedback fellas?...Thank you!
No I really don't know what you mean.
Are you saying your truck used to be EFI (22RE) but someone converted it to carburated (22R)? Maybe a pic or 2 would help.
The answer also depends on where you live. Some states (CA) are fussy on emissions. Where I live, anything pre-OBD2 ('96) doesn't get tested, they don't even open the hood.
and yes...it was a 22re...on the manifold exhaust it has a sensor that sticks out..about 3 inches long...i will get pics...thanx
I think some 85's were carbed-were they not? If not, you're screwed. And you may be anyway, if the law requires you to comply with the original vehicle equipment guidelines. There's no way a carbed engine will pass EFI emission requirements.
Ya, you know, after some thought... it could very well be that there is an O2 sensor on that thing from the factory. Is it hooked up to anything? What makes you think it was converted to a carb? If you run the VIN thru the toyodiy.com website, it will tell you how it left the factory, and how it was equipped.
KLF, Did Toyota use "feed back carburetors" with any kind of wiring going to them? If they did, the oxygen sensor is just there for very basic fuel trim control.
It is not hooked to anything...The Air cover/carb cover...has a part missing...it comes out the side and connects to the exhaust manifold and feeds out the front..my 88 has it?...not sure what it is called....?
keith they did have feedback carbs my 84 had one. and creek the horn you are referring to only takes and sucks hot air off the exhaust manifold when the engine is cold, once it warms up a thermo damper closes and it sucks air from the engine bay. it is only to aid in warmup.
Question to you guys...I am selling this truck..I have put on a new alternator,new power steering pump,rebuilt the front end dif,rebuilt bottom end,rebuilt carburetor,new chain,valve ajust....I am asking 3800 for this truck..well short of what i have in it...Am i far off base here?...I am not getting any bites at all...i figured straight axle guys would be jumping on this...I am still waiting...any feedback from y'all?...Thank you!....1985 4x4 extra cab not mint but clean..body in good shape.
Need to see pictures. Just what is wrong with the front end?
Yea even for the rust belt guys......its a bit much. If the motor was ok(the bottom end by the way..whats wrong with it?) it might be a diffrent story?
I put in a rebuilt shortblock...Front axles were leaking real bad so i had them rebuilt and sealed..dang i paid 900 just for that...New clutch rebuilt carb..new power steering pump..,chain,alt,is 3500 fair??...Thank you for any feedback! i have to get this sold...but i do not want to lose all i put into it....C
ohhhhhhhhhhhhhh I thought you said you needed those items. I was like wtf is wrong with his engine now?:D
yea as long as the rust was little....sure that might be ok.
Sadly I hate to say this. Most people do loose. Yes I know it sucks
Thank you cruiser...Ya i think they sittin waitn for me to go dowwwwn...My bottom would be 3000...I have 4500 in it:crybaby:..Ima gonna hold at 3500 ffor a few days see what happens...cheers thank you for the feedback!...C
