83 FJ40 suspension?
Gretna, NE
I would like to put a new suspension on a 83 FJ40. What brands do I check out or what is available? I've been told spring lengths from 81 to 83 are longer than pre 81 cruisers.
not sure if they are longer, but I thought they are a bit wider than pre 81's
Yes wider, not sure about longer, but I don't think so. OME springs are a good choice if you don't need more then 2.5" of lift. I have a set of MAF safari 4" on the front of my 82 FJ40 with wider bushing to make up the difference in width on the spring. (pin size is different also)
I have heard that CCOT also make a good set of springs.
hope this helps
Clay (stuck in no mans land 81-83 FJ40)
nope....
Springs are identical, except that the spring eyes are different.
do a springover. And be done with it
toy4fun said:
Are you sure on the width thing ? becase I can't fit my 82 springs in my 70 spring hangers.:)
Yep, the spring eyes are different.
they are like a FJ60 not like a 40.
However, the spring widths are the same.
I have OME on my 82 fj40, very happy with it.
This is what I was told then I asked CCOT what the diffrence in pre 1981 and post 1980 JF40 spring were
<The late model FJ40 springs (8/'80 to '84) are longer than the early model
springs and have larger spring eyes / bushings... Thanks>
ANYONE know what the measurements are? Thanks:)
Jim S. said:
I'm with Pimp. Have OME on my 83 & am verry happy with them.
Me too, but I want a little extra lift and was wondering if 60 or 55 lift springs would work or do I need custom springs? and no I do not want a SOA on this Cruiser:) and I know that other out there that would like to know;) Thanks!!!!!!
Pinnacle's are bouncy....I have them on my 82' FJ40. It takes them a bit longer to break-in and they work better with a GOOD offroad shock. They work well enough and they fit great. It's a bi*ch figuring out which direction they go however, since the front and the back of the shock is not marked.
