I still have to install my pulling cable on the drum...
I know Warn says to stretch the cable onto the drum with 1,000lbs, but i need to get the first 5 wraps on there... Is there any "trick" or do i just "get it on there" and then tension it for the remainder?
Are you going to use wire rope or synthetic rope? The tension thing (and getting the wraps on nice and straight) is more important for wire rope than for synthetic, because the wire rope can kink otherwise. Synthetic is much more forgiving in this regard.
When I used wire rope, i used to tie the line to a tree, etc. and then put the truck in neutral, and let the winch pull the rolling weight of the truck to tension it.
Nowadays I run synthetic line on both of my winches/trucks, and I just stand in front of the fairlead and just tension the synthetic line with a gloved hand as it winds on.
