- Joined
- Feb 14, 2007
- Threads
- 33
- Messages
- 205
Hi Guys,
I need some advice on how to repair a broken mounting tab on an 8274 that I just purchased. I bought the winch and started taking the two halves apart to inspect and lube the gears and noticed that one of the three mounting tabs was broken (the one and only one on the inside). The two outer ones are ok. The tab broke on the upper half so the bottom one where the threads are is ok.
The material looks to be aluminum. Is this a common issue or is it unusual? What would be the best way to repair this? Is there a load on the upper or is it just to keep the two halves together and tight for the gasket? Maybe JB weld?
Thanks in advance,
Roman
Thanks in advance,
Roman
