eBay 82 FJ40, original paint, winch, power steering and cold cold AC
Houston
Since owning it I have had it gone thru with a fine tooth comb (by Javier's Auto Unlimited...AWESOME FJ SHOP!!!!!!). I replaced all 4 Old Man Emu shocks, replaced all brake lines with custom steel lines, replaced the rear wiring harness for the brake and license plate lights, corrected a vacume tube / timing issue, replaced the catalytic converter with a new double wall heat shield version, had the entire exhaust re-routed with custom exhaust heat shield to reduce rear cargo area heat, installed thermo tech heat shields, replaced interior dash bulbs with 5X brighter, replaced center ash tray with brand new reproduction, installed rear rubber floor liner, installed 6 bolt class II receiver hitch and all fluids / grease, tune etc etc....
My situation has changed and I need a 4 door:mad:
Toyota : Land Cruiser: eBay Motors (item 160477567273 end time Sep-12-10 20:07:03 PDT)
I don't think I could ever sell that - needing a 4 door or not!
Fantastic 40...
Technically speaking, it has "4" doors.
I hope things work out for you and you are able to keep it. Not too many like yours in that condition still around.
Price?
