81 fj40 starter
I posted before about my 81 fj40 stater issues.
I bought and installed a cruisercorps remanufactured starter a year ago. Have had issues with it not clicking or starting. If I wiggle the starter wire from the ignition it will start.
I have replaced about 12 inches of the wire (black with white stripe) that was corroded . with crimped on connectors (they appear tight, cant pull them apart). and the spade connector on the solenoid is tight. Still have intermittent issues with it not starting/clicking until i wiggle that wire. I am at a loss.
Well maybe your ignition switch/box is going bad (inside). Corrosion can crawn under the insulation on wires - crimp connectors can corrode in the crimp. Use a remote starter switch to test the starter. If it works every time with the remote its not the starter.
The ignition wire will eventually wear out. Best to just replace it. Looks like you found the culprit. If you are curious, you can connect a remote start switch(connect one end to the starter solenoid and the other to the battery. At the ignition switch, turn key to the "on" position and use the remote switch to start it....and see how it behaves. I always add a ground from the frame to the starter. Seems you find this ground jumper on fj60 and newer fj40s.
Interesting question. I've got that same problem on a tractor. I checked the battery, had good voltage and ground, but still just a click. I put a 3A battery tender on it, it flashes "charging" for a few minutes, and then goes solid "charged", and then the starter works fine. Every time. I'm not sure if it's a poor connection in the ignition circuit or if I have a small electrical drain somewhere like in the relay box. Frustrating.
You should load test the battery. You can have voltage (pressure) but low/no amps (flow). Inspect/clean the connections, look at the crimps - corrosion can crawl under the insulation and inhibit flow of electricity.
3 minutes at 3 amps isn't a lot of power. I like good battery tenders - cheap ones fry batteries over time. I have mine on a switch, I usually leave it on over night a day or two every week.
The cruiser corps starter I installed last year had a grey wire pigtail that I am assuming is a ground for the solenoid that is available on some model FJs.
Maybe is should find a place to hook this up for a ground. My starter wire did have corosion on it but removed the 8-10 inches of wire affected by this.
Probably will replace the ignition switch too.
You could be right on having poor connection. Sometimes the terminals will oxidize over time. Sometimes it may be at the threshold where it needs a tad more current to get going. You can start by cleaning all the terminals though out the circuit with a wire brush(I like the tiny wire brush You use to the wire welder.). You could take starter apart clean it, relube it, clean the armature with emery cloth, be gentle with. Or put on a drill and rotate it and buff it with file and do lightly. If it's in bad shape definitely use a file to even it out. Make sure the brushes are making good contact on the armature. Taking pics will be a help when you put back together. If it still does the same thing you have to just bite the bullet....they are not that expensive to replace....well this was before "tariffs"...just saying.
