80 Torque Spec Range?
jaymar
SoCal
Can anyone list the lowest and highest torque specs for the FZJ80? Torque wrench shopping...
Thanks for any help!
Also keep in mind that the broader the torque range of a given wrench, the less precise it will be at hitting a given torque value, especially at the extreme ends of that range. Not that we have to be SUPER precise.. But it makes the case for finding what is commonly used and buying your first wrench with that range of values near the middle.
i actually think i can answer this one for you. The lowest torque i've seen is 5.5 ft lbs , and the highest ive seen is 305 ft lbs (front cranshaft bolt). The answer you are looking for, is there is not 1 torque wrench that will cover everything. I have 4 actually
This. I have 2: 50-250 ft-lbs, and 5-75 ft-lbs, and they cover most of what is needed. When I did my oil pump cover I rented one for the 305 ft-lb crank bolt. I can't see buying one pretty much just for that bolt.
I've no illusion of getting away with a single torque wrench--just need to know the overall range. Thanks for the figures!
If we toss the 305 ft-lbs as an outlier--what's the next highest torque spec? Thanks!
to be completely honest I bough the 3 that horrible freight offer the smallest is inch/lbs the second is in NM/KG and the 3rd is their big one its in ft/lb got all 3 for less than $100... If I were using them for service work and not for shade tree mechanichin then I'd get a name brand set, but I ain't so I didn't... Lol
