Does anybody have any old 80 series coil springs kicking around? Old and bagged out is ok.... even broken would work. Preferably free or cheap.
do you want for them? Are they stock height?No I don't want to slam it. I have a hair-brained idea which Ken thinks is crazy but I think it just might work. I want air bags right. No springs. But I don't want to modify my spring perches.......... because.......... well I don't really have a good reason. Basically I want the option to return to coil springs if I hate air bags. Or if I sell the truck. Or something.
So I'm thinking I cut the ends off some springs. Just enough to fit in the spring perches. Then I fabricate an air bag mount. Imagine the truck sitting on coil springs, except the middle section of the coil has been cut out and replaced with an air bag.
Obviously the danger is that a deflated bag could fall out of the truck. So I'm thinking a small bolt or even a tack weld would hold them in. So if I rip a bag on the trail, I just pull the bolts or grind off a couple tacks and swap in a new bag. Or if I buy a LHD 80 and swap in a diesel![]()
and sell my RHD 80 then I just pop the springs out, and pop in my bags on the new truck
Why not bags inside the springs? Just trying to understand what problem you're trying to fix.
