Anyone have experience with these or other rear window vents? Do they help much with let the heat out during the day and cool air in at night? What’s the construction quality? Recommended?
They look like a good way to let hot air out while keeping bugs outside while camping.
Visual Auto Werks has a 15% off sale, so I’m likely going to pull the trigger to check them out.
“These window vents for your 1990-1997 Toyota Land Cruiser 80 Series can be used in several ways. Camping to prevent insects from entering the cabin with our mesh screen insert, daily driving to eliminate wind turbulence or if you have pets in the back seat, or stand out from the others at a show.
Window Vents are made of high quality ABS plastic. Vents will come with a choice of Black, Silver, or Brass colored rivets.
(If mesh is chosen with order, filter screen cannot be removed and is permanent within the product)
The window vents are NOT permanent when installed. They easily slide into the factory window track, the window slides into a channel along the bottom of the vents for stability, and to remove you simply lower the window and angle the vent downwards and out. Installation instructions included.
Will fit the following Vehicle:
1990–1997 Toyota Land Cruiser 80 Series / Lexus LX450 Rear Window Vents (J80)
1990–1997 Toyota Land Cruiser 80 Series / Lexus LX450 Rear Window Vents (J80) Upgrade the ventilation and functionality of your Toyota Land Cruiser or Lexus LX450 with Visual Autowerks Window Vents. Designed specifically for the 1990–1997 Toyota Land Cruiser 80 Series and 1996–1997 Lexus LX450...
www.visualautowerks.com
- 1990-1997 Toyota Land Cruiser 80 Series
