On the highway at really any highway speeds say 55-80, it will downshift up a hill like it should but rarely upshifts afterwards. Hit cancel on the stalk and it immediately upshifts. What would cause this?
Normal function of a Cruise control system that's 30 years old.On the highway at really any highway speeds say 55-80, it will downshift up a hill like it should but rarely upshifts afterwards. Hit cancel on the stalk and it immediately upshifts. What would cause this?
I agree. Also, this is both electrical and mechanical, I wonder if adjustment of that cruise control throttle cable might make a difference.Normal function of a Cruise control system that's 30 years old.
The downshift is a combination of throttle position, speed sensor, and the ECU throwing the solenoids in the transmission.
The upshift is exactly the same, but with the CC on, the upshift can be very delayed depending on the situation.
On my LX450 it will upshift well after I crest a hill and the throttle has been backed off for a while.
Yes, it takes some time and can be annoying.
My cc has been operating that way for years. When I’m in Hill country, I just drive without the cc.On the highway at really any highway speeds say 55-80, it will downshift up a hill like it should but rarely upshifts afterwards. Hit cancel on the stalk and it immediately upshifts. What would cause this?
When this happens, if you accelerate to 5 to 10 miles an hour over the set speed and it still does not upshift, to me that would mean electrical. Above the set speed the cc is relying on data to shift, if I’m not mistaken.Normal function of a Cruise control system that's 30 years old.
I call that analog driving.I'd probably just turn CC off and drive it the old fashioned way,
"changed" or "flushed"? The former is useless; the latter is what you want to do.I just changed it.
In the future, I'd suggest flushing, as it's not only much easier, it also carries some solids out with the fluid, which wouldn't necessarily happen with a gravity drain.When I did the engine about 30k ago, I put the torque converter flat on a 5 gallon bucket and drained as much as I could and stood the trans up as well. As I recall I captured about 9 quarts or more. I cleaned the pan, the screen and put new neo magnets in it so 30k later I drained the gallon or so that came out and added new fluid. It seems happy except for this issue.
What items are you referring to?Has anyone replaced all the items on this thread and was able to fix the problem?
If any of those were an issue, the transmission wouldn't shift properly without CC.Tranny solenoids, speed sensor, and throttle position sensor
