Hey all, I hate to make another thread so early but I have a question and despite hours of research here and elsewhere- I can’t find any insight to my specific question.
Backstory: I bought this 80 from a member on the forum SOLD - 1997 LX450, Built w/37's, 5.29, ARB Front, 4x4Labs Rear, 183K Miles - Location: Boise, ID 83704 (that was the original sale he bought it from a little over a year ago but it’s more complete and he didn’t do much to it)
The truck has an OME “level stance” lift (no further information, one of the few things without a record) in addition to the 30mm spacers with 37s.
The issue- There is a distinct driver side lean of 1/2-3/4in without the 37in wheel on the 4x4 labs bumper. With the wheel mounted, it’s 1”+. I can’t move the wheel to the passenger side because of the mounting hole location. If It were 1/2” with the tire I would just ignore it but at 1”+ I need to do something.
So here’s the question: are trim packers possible with the 30mm spacers in place? I plan on removing the springs to make sure the longer ones are on the drivers side, but as it’s so high up I’ll have to go to a garage with a lift to do so. If I can use trim packers as well, I’d like to have them on hand in case the springs are correct so I can do it all in one shot. If it’s a case of the springs being mounted incorrectly, easy fix. If I can’t use trim packers in addition, what do you recommend as a fix?
I plan on going back to OEM control arm bushings and installing caster brackets/ ext brake lines since it’s still just using the OME caster bushings with the full lift plus 30mm spacers so no worries about going up in lift there. My other option as I see it is to take the 30mms out of the passenger side and shave them or do 2 10mm packers but I’m afraid this will create clearance issues with the tire.
FYI my hub to flare distance is ~PF- 23.5in PR- 24in DF- 23in DR- 23.5in for a rough idea of lift without the bumper mounted wheel.
Thanks in advance for any help and hopefully this helps someone in the future with the same issue!
