The FJZ80 is a great rig! You won't be disappointed! I bought my '95 FJZ80 in 2003 with 30,000 miles and have had nothing but great service from it. Unfortunately, it doesn't have factory lockers (other than the center dif lock), but that will be a future project.
The only issues I've had over tha last 109,000 miles that I've put on it are the following:
1. Starter replacement
2. A/C clutch and compressor replacement
3. Brakes every other year
4. Window in the passenger side rear door keeps dropping into the door every 8-12 months. The channel/base that the glass sits in that is attached to the lift mechanism eventually slides forward allowing the lift arm to slide right out of the end of the track when the window is half way up/down, at which point the glass drops into the door. It's probably due to lift motor leverage still being applied when the glass reaches the top or bottom of it's travel. After being opened and closed 100's of times over the course of a year, all that incremental movement adds up to being enough to disengage with the lift mechanism. I've tried various epoxies to secure the glass to the channel/base, buy without success. Takes me 15 minutes or less to fix it now.
5. Various dash and indicator lights burnt out, factory stereo head unit displays don't light up any more, CD player no longer plays (I replaced it once and the used replacement failed within 6 months). Some of the lighted buttons on the dash have bulbs that are integral to the button and not replaceable (technically they can be replaced by cutting the leads and soldering in new microlamp bulbs).
I haven't done any serious off-roading with it, just frequent weekend trips into snow country to go skiing.
Overall, a great rig with room for the whole family and the dog.
