80 series landcruiser
ceduna
Hi guys, I recently got a flat battery in my 80 srries and ever since then my sub tank will not activate and my main fuel tank gage won't work.
Just wanting to know if there's an easy fix to this (fuse) or if its a big problem and if it can be easily fixed
Cheers
Is the sub tank OEM or aftermarket?
What year is the truck? Looking for the fuse for the fuel system. They could be on the same fuse
There are 3 different fuses that are labeled as fuel injection system. Look at this page
Ill have a look now cheera
The 10th character of the VIN number will be a letter. It tells you what year your truck is.
The easier way is to plug your VIN number into this Toyota Vehicle Specification page.
Welcome to MUD by the way. I see this is your first post.
There are 3 fuel injection fuses. I'd check these first.
#3 fuse in the fuse box under the hood
#4 fuse in the passenger compartment
#12 fuse in the passenger compartment
There is also a fuel pump relay.
Here is a thread discussing it's location.
This thread is more specific to your problem.
Cant find the the fuel fuse relay box or the abs, nothing sticks out to find
Just checking since you're in Oz - is this a diesel or a petrol powered rig?
Would be really helpful if you could give us the build date and model. Both should be on the firewall plate on the passenger side (Right hand drive)
So its a 92 model, 5 speed diesel, checked the fuses under the steering wheel and the bonnet and no blown fuses
Factory turbo diesel, so HDJ80 or the N/A HZJ80?
Righto. So, just making sure I've understood properly:
Main fuel gauge isn't working? But truck will run from main fuel tank fine.
Is the subtank gauge working? Truck will not run from subtank?
Correct with the main tank but the sub tanks gage is fine just not activating when ever I push the button for it, the light says its on but not actually on
