Definitely check all your wiring and the fusible link. Easy continuity test. Make sure everything is hooked up correctly and all connections are clean. If you have really old original wiring, I'd recommend ether making or buying new wires for the large ground wires that ground the battery to the chassis and chassis to engine, and the large power wire that goes to the starter. When I bought our '91 the wires looked ok, but on further inspection water and other stuff had leaked into the heat shrink at the terminals and completely corroded the wire inside the sheathing. Does your battery have a full charge? Silly question, but some times its the stupid things that are easy to miss. Maybe also check the 50amp AM1 fuse in the engine compartment fuse box.
