- Thread starter
- #21
That's news to me. ThanksOn a cold engine the fluid in the radiator should be at the top and the fluid level in the overflow at the cold line. Filling the overflow to half full is a mistake
Park it on a slight incline, nose up, preferably cold. Check the level in the overflow tank, filling it to the cold full line. Remove the radiator cap and and make sure the radiator is full, open the heater valve and start it and let it run until you are up to temp and know the thermostat is open. Any bubbles should purge themselves out the top of the radiator. Shut it down and cap the radiator. Check the overflow tank again after its cold again.As a follow-up, I'm wondering if there is an air pocket in the coolant. You mentioned burping the system. The last change I did, I first filled the block from the hose, then the radiator. Is there a best practice for eliminating air in the system?
Thanks again..
Awesome. Will do. Thanks again!Park it on a slight incline, nose up, preferably cold. Check the level in the overflow tank, filling it to the cold full line. Remove the radiator cap and and make sure the radiator is full, open the heater valve and start it and let it run until you are up to temp and know the thermostat is open. Any bubbles should purge themselves out the top of the radiator. Shut it down and cap the radiator. Check the overflow tank again after its cold again.
If you are having to refill the overflow after you know its been burped, then you are likely losing coolant elsewhere. Hoses are the quickest to check, make sure to include the PHH and intake manifold hose. A failing head gasket can also cause a loss of coolant, I know that from experience.
jack the front end of the engine up, open the cap so that it is at the highest point....start the truck and turn the heat on full blast and wait for bubbles to escape...occasionally squeeze the top radiator hose to let more air/bubble out and fill the radiator with more distilled water or coolant. After about 5-10 mins. increase your idle to about 2-3k for about 5-10 second at a time...Put the cap back on and watch the engine temp gets up to 180F or so. Fill the overflow to max level and you are done. Keep an eye on your overflow bottle for the next few days, add coolant as needed.As a follow-up, I'm wondering if there is an air pocket in the coolant. You mentioned burping the system. The last change I did, I first filled the block from the hose, then the radiator. Is there a best practice for eliminating air in the system?
Thanks again..
