80 series clock wiring
Metro NY
I'm going to put an 80 series digital clock into my FJ60. I have seen a diagram of the wiring for the 4 pins on the clock but I'm not understanding. can someone clarify which tabs get what? (please reference looking at the back of the clock with the slot for the tab on the plug in the UP position - that will be with the clock on it's side)
I tried to put hot to one side and ground to the other (hot to 2 and 4 as per my diagram) I even switched to the other side thinking I might have 2/4 mixed up with 1/4. I couldn't get any reaction from the clock. The digits should light up when I have power to both "hot" side tabs right?
Any help would be appreciated.
mark
According to your orientation of the clock, pin 1 is top right, 2 is top left, 3 is bottom right and 4 is bottom left.
Pin 1 is ground, 2 is 12v with headlights/parking lights on, 3 is 12v constant, 4 is 12v with ignition at ACC or ON
So 1 & 3 are always connected to keep the time set, 4 makes the digits visible when the key is in, and 2 gives it dimmer control.
HTH!
That worked! Thanks....
Now to figure out where to mount it... I'm thinking of putting it where the Seatbelt and Parking brake warning lights are.
