80 running rough
Air Capital of the World! Wichita, Ks/Choctaw, Ok
I'd like to thank all of you, this is a great site, I've been lurking around for sometime now, learning about these vehicles. The info is unbelievable. (done sucking up....:))
I just bought an 80, 153k and it started running rough today, like missing a few cylinders. When I bought it the owner said that it might have a computer problem. I've driven it for a week and no problems except for the CEL light on and Air bag light is on constantly. Then today it started missing. I replaced the distributor and the rotor, which were in bad condition but that didn't help. My next option is to check the plugs. Got any ideas?? :rolleyes:
Thanks
Check and see what the CEL is at Autozone or some place that has a OBD2 reader.
Is this a flood car....?
No, I work with the guy, I'd hope he would have told me.........but I'll ask him tomorrow..........
Get it scanned or get a scanner. Start there before you start replacing things that might not be the problem. And welcome
I'll do that tomorrow also.....thanks
Where is Dougie when you need to know..... year, mileage, recent maintenance, etc. :D
You were given advice to get it scanned but we don't know if you have OBD-II or not. We don't know if it is a diseasel or a 3FE, or a 1FZ-FE, or a Chevy V8.
They are just guessing...
-B-
Sorry........1995, 153k, sat for about 2 years, the reason the x owner quit driving it was that he was told he needed a new computer, so he parked it. I thought that it could be the injectors, but its been running great until now...........
(Sorry, I missed that it has air bags which means it is 95-97)
96-97 are OBD-II. '95 is a bit of a hybrid with partial OBD compliance.
We have very rarely had computers (ECM) fail. There is a little problem with the '93s but that is all. Of course, it could have been damaged but that is still pretty rare.
The 3 most common problems causing your symptoms are:
1. Cracks in the intake tube
2. Short/open in the engine wiring harness (usually by the EGR valve, sometimes behind the glove box.)
3. Fuel pump relay.
-B-
3. Fuel pump relay.
-B-
Thanks, I'll look into them. Glad to hear these don't usually have ECM problems.
I'm also thinking that the fuel filter could be clogged up after sitting that long with an almost empty tank. I've only put about 150 miles on it since I got it.
The fuel filter is a little tough to access. It is under the intake. SEARCH for threads on replacing because there are some good tips that will make the job easier.
There is also a fuel filter 'sock' on the pickup for the fuel pump inside the tank. This is not difficult to get to and all you have to do is remove the rear seats and open the access panel.
-B-
Ditto ?? fried wires in the engine harness near the EGR valve (guess), but check the usual suspects as mentioned above, including the simple ones, like loose or bad ignition (sparkplug) wires.
I would ask your friend how far he got with the diagnosis two years ago; if he took it to a shop he should have some receipts, or they should have the info on their computers. Was it a Toyota shop--?
I know the airbag light will come on and stay on if the battery is dead for awhile; do not know how low the voltage has to go and/or for how long, for this to happen. I would assume for more than just a few hours, as it doesn't come on ie: when disconnecting the battery and working on your vehicle.
If you clear the codes (may need the Toyota handheld tester, not sure) the airbag light should go off. Happened to me when I parked my 80 for year when in the sandbox, the battery was like 5 volts when I got back. The dealership predicted doom and gloom, new airbag, this sensor or that. Nope, just due to a dead battery.
-B-
I know about the filter 'sock', had to change one on an 85 4Runner. Toyota made that an easy job with the access panel under the seat.
gray, nice handle, happens to be my last name!!! I'm going to do some investigating on the EGR. Seems to be mentioned alot on this board. I put a new battery in it last week, so that shouldn't be the problem. Plenty of volts. I've definatly got a trip planned to Autozone.
85badger;
What I was saying is that the Airbag light being on is possibly related to a long-term previous dead battery situation ie: while it sat for two years, not due to the current condition of the battery.
All you may have to do is have the codes cleared and the airbag light may go off and stay off if that is the reason it came on; a dead battery while it sat for two years.
I do not recall the details for why it comes on something about the airbag brain and/or ECM. If it does not get power for a prolonged period the airbag light will come on, all related to safety; ie: the system will not work without power, so if it doesn't "see" any power for a certain period, the airbag light will come on.
Wallmart or autozone will have an OBD scanner that will clear codes. It wont read o2 voltage or tps stuff etc like a snap on or OEM but does most user maintenance.
I got one like that. I borrow a friends snap on scan tool for anything it cant do. Yet to need that for the 80 anyway.
Change your plugs, plug wires, and o2 sensors. May or may not help but probably overdue so git er done while you are in there. The connection at the coil probably has corrosion. It sits vertical like a cup and it was the only wire I pulled out when I replaced the wires marked Mfg 1995 that had significant corrosion.
same problem
I recently purchased a 93 with a 180,000.I bought it from the second owner with every service record from time of purchase.It started running rough so I took it to the dealer that new the car since new.First they did cap and rotor, then alternator and plugs/wires,and when that didn't work they started talking injection. Just for shclitz and giggles I swapped a brand new battery i bought for my other car and viola' purred like a kitten. Not sayin it'll work for you, but had i done that first I coulda saved some cash.:doh:
When does it run rough? At idle, at XXXX rpm, all throttle settings, when hot, when cold?
My stumble was fixed by replacing the plug wires and changing the ECU temp sensor. I can't say for 100% certainty which one was the real fix or if it was both. The wires that were on it were not Toyota and the temp sensor resistance didn't change smoothly with temp change above 100*.
Step one= pull the code. Dont go throwing parts on her just yet.
Thanks for all the great ideas. I took it to Autozone, kid couldn't find the port so he said that he couldn't read the codes. I didn't know where it was either, but eventually found it at another shop. Behind the little cover for the fuse box. Anyway took it to a local shop and pulled the code. Number one cylinder misfire. So had them change the plugs and put a can of BG44k in the tank and all is well, runs great again. Plugs looked like hell, so it was a good thing to change them. Cleared the codes and the CEL light was off for awhile, now its back on though. Still running great. I'll take it back to the shop and have them see what's up this time. So I guess bottom line....get your codes read by a reputable shop.
Thanks Guys!!!! ;)
Update........after getting plugs changed, the CEL comes back on....checked the code (PO401) EGR. Now I have to research and fix that, hope its not too much of a PITA to fix! Also, this 80 sat for nearly 2 years....could that account for the vibration that I'm getting? I'm almost positive that the tires have flat spot in them and since its freezing around here they haven't be able to smooth out? They are stock michelins and for all I know they could be way out of balance. Just fishing for an explaination....hoping its not something in the front axle or driveline.
The PO401 is a ccommon problem, and there's plenty of info here in how to diagnose and repair. At some point you should go back and install new Toyota plug wires. They can make a noticeable difference on high mileage trucks.'
If it sat that long, it could easily be the tires.
