I asked some time ago regarding a PTO for an 80 with zero luck. I had tried a few vendors that dealt with importing non-US spec models and received no answer from them either. If you happen to find something please pass it along. Good luck on your quest.
and also cut the moustache thing under the radiator
to fit it back closer to the chassis and a litle higher.Thanks a lot redstang.Yep, I got one on my 80. The PTO is totally different from the splitcase transfer cases. They work great. They have some type of brake holding the load even if you step on the clutch.
You need a transfer case with the open port and cover on the side.
That's the same idea I had in mind, run a hyd. pump off the PTO to a Hyd. winch. Dan confirmed what I had assumed for US market 80's that we can't install a PTO. I'm not that interested in replacing my transfer case with a non-US unit at this time. There are other things I need to accomplish first. However, it is good news to know someone has similar ideas and a source of parts. CheersAnd i could be ready to part out with my 80 series winch for an hydraulic one with a rear PTO (150 dols from SOR) I would then fit an hydrau pump on teh PTO or rear PTO for teh winch.
Bye.
Max.
May be you don't need to fit another Tcase? That seems rather weird that they would use different tcases between the petrol and diesel ones! Not verry cost effective!![]()
