80 Mudflap Ideas
Auckland, New Zealand
I can't believe these survived the trip to the dunes recently. Each time I got out of the car I looked and they were still there! I think they could do with being a LOT shorter, on a previous truck I cut them with a jigsaw and that worked, but that seems a bit too Maori for this 80 which I'm so fond of.
What good ideas are there for modifying or replacing these, are there any good looking, improved bolt on versions? Be keen to know what the folk here suggest.
Cheers,
Found these on ebay a couple years ago
Used the same mounts.
I stayed with stock length up front, but cut the rear ones just below where its says "Land Cruiser" with some shears.
View attachment 1553455 View attachment 1553456 View attachment 1553457 I can't believe these survived the trip to the dunes recently. Each time I got out of the car I looked and they were still there! I think they could do with being a LOT shorter, on a previous truck I cut them with a jigsaw and that worked, but that seems a bit too Maori for this 80 which I'm so fond of.
Cheers,
Is that politically correct?
Cheap alternative I did.
I cut mine way short when I first bought the rig. Did not work. Still got bumped/pinched in the rocks and it was risky that it would end up tearing off the flair also, since they are fastened together, so I removed them. I can't see it from the driver's seat, so I don't care so much about appearance.
Yeah, strictly speaking it's not super politically correct, albeit the saying with regard to things that are 'fixed' in a functional but inexpensive manner is quite common in NZ. I guess it's how you refer to the use of the phrase, it would be more inappropriate in some instances, and somewhat accepted in others. If I was to say to a Maori directly, 'that's a bit Maori mate' when he has a coat hanger jammed into the front fender for an aerial, he would laugh, a bit like Billy T James and it wouldn't make the news if you know what I mean.
Just picking at you ;)
