80 lc vs ifs 4runner
looking for a comparision between a moderatley modded 1995-1997 80 lc/or lexus 450 vs a simularlly modded ifs 4-runner. lc would have 33" tires and of course both factory lockers. to make it an even playing field, the 4runner would have 33" tires and lockers at both ends also.
looking at trails rated around 4 and as a traveling vehicle to take the trails on 1000 mile trips with a family of 4, 2 of them being pre teens.
thanks, gerald
a.k.a. newbie
80 series, 'nuff said.
IFS vs SFA? Cmon man....Your going to get an unbias responce around here. That being said......80 all day! :)
They are completely different vehicles. Both have their strong points. The 80 series is a no holds barred heavy duty truck. It has lots of unique features, like full float axles, solid front axle, coil spring suspension, heavy duty frame etc. It is designed to move you and yours through the world's worst conditions for 20 or more years. It is massively overbuilt for USA conditions.
The reality though, is that we don't have the world's worst conditions here. In fact, we have one of the best road systems anywhere. Our trails are at most 3-4 days long, and then you are back on pavement.
So the 4Runner is not a bad choice. It's lighter duty, smaller, gets better fuel economy etc. It's all good, but it isn't a Land Cruiser. On all but the worst trails it will perform just fine, especially if you don't go beyond 33 inch tires, where the heavier axle of the 80 series will have significantly more strength.
It comes down to what you want. To me, the 80 is like the last of the Mohicans in the USA, and worth owning for it's unique status in the LC world. You can bet no truck like it will be built again. The only real fault of the 80 series is the lousy fuel economy. Can you live with 12-14 mpg long term? You also need to consider that the newest ones are 10 years old, and most have lots of miles already.
If you just want a 4wd, then the 4Runner will serve you well. If you want a Land Cruiser, the 4Runner will not do. You could look at other Cruisers as well-100s are very nice and plush, 60s can be had pretty cheap, and even an FJC might meet your stated need. If you have tons of spare cash,look at the 200 series. One hint is that the back seats of all of these choices get pretty small when the kids go from "pre-teens" to actual"teens". BTDT.
If you plan occasional use, but long distance trail work at the destination, the 80 can't be beat. Then the poor economy does not matter that much. If it will also be a daily driver, with gas prices headed up and up, you might consider something with better economy. If you want unique, then it pretty much has to be a Land Cruiser (they only sell 10-14k of them per year,vs 100k 4Runners).
I started four wheeling after rebuilding the engine on an old 4runner. It was an '88 with the 6 cylinder engine, manual 5 speed, and 33" Goodyear MTR tires. It did not have lockers of any kind. I had a lot of fun spinning tires and really learned to find lines that the IFS could cope with. I removed the front sway bar which seemed to make very little difference. Torsion bars seem to be very limited in their movements. It seemed one of the front tires was always off the ground. This vehicle would leave me exhausted at the end of the day, but feeling as though I had tapped all of its potential.
A month ago I took my new to me '93 FZJ80 up the same trails. I used the center diff lock only to replicate the 4Runner 4WD setup on several sections. I was able to go right up some of the same inclines the 4runner would slip on, probably due to the extra weight and SFA.
The Cruiser has air lockers that make all the difference in the world. However, their full potential would probably not be realized on a 4runner with IFS and one wheel hanging in space.
With the lockers on I was able to climb over every obstacle without pause, then enjoy the carnage watching my friends scrape, spin, almost flip over, and give me dirty looks. There is no going back. Even a Jeep Rubicon had trouble following me up one section. We also got to enjoy a 2005 stock 4runner be dragged over some gnarly rocks on a line. Lifts and sliders should be a given.
I have a lot of good memories in the 4Runner (very proud of the engine rebuild at 220,000 miles). My brother has it now, hopefully he will get hooked and have some fun.
With some good friends either vehicle will make it to your destination.
No one else on here knows about it, but the Land Cruiser gets really bad gas mileage (10-12mpg). The 4Runner got 17-18mpg but it was a total dog (before and after the rebuild). The Land Cruisers have a less cramped interior for me (6'-4").
The Cruiser has some 37" BFGoodrich All Terrains, which seem to grip just as good as the 33" Goodyear Mud Terrains and produce a lot less road noise. The MTRs have some really stout sidewalls and weigh a ton.
You could always put a SFA and lockers in a 4Runner, but if you purchase a cruiser then both are available factory options.
:bounce::bounce2::bounce::bounce2:
Have Fun,
Mike
I am a small guy, but the 2nd gen 4runner I had felt really cramped compared to the 80 series. The seating arrangement was tight, and felt "dark" and closed up. The cargo area was high, hard to access (have to roll down the tailgate window every time you need to use the cargo area), and small. It was also gutless, though I'm sure the newer ones have solved that problem.
80 hands down!
My last truck was a 97 4runner (have not changed name yet) with ARB lockers FR/RR and lots of armor. When I bought my locked 80 I took it out on the same trails I used to do with the 4runner and the 80 was like a rock. Where the 4runner was tippy in areas the 80 held its ground;)
from what i was reading the lc looked like the best of both worlds, solid front axles, locked at both ends. it makes the purchasing of one easier hearing some old 4runner people happy with the swap.
i think the wife might go with the lc interior, she is not liking the 4runner interior. might have to go with the 450 for the icer interior, did they come with the lockers also?
the lc prices are cheaper than i thought, they really are not much more than a 4runner.
yeah, the gas mileage is pretty weak. a friend of mine bought a 450 when they first came out in the late nineties. he loved the ride and truck but complained and finally sold the truck because of the poor fuel mileage. i would not want to lift it too high because it would have to be driven on family vacations when we go to the mountains. 1000 mile drive oneway from ms. that is why i was thinking of the 33" range tires.
i'll be researching the 80 series until after christmas before i go looking for my truck, alot more learning to do. anybody here wheel the 450 lexus. i guess it has the same off road abilities as the 80 series.
thanks, gerald
The 80 comes stock with a tranny cooler too.
LX450 is essentially the same as the Land Cruiser, especially for "wheelin" purposes. Only real differences are trim/stereo/HVAC. They had optional lockers too.
The only thing nicer about the interior, to my eye, is the OEM wood trim is pretty nice stuff, it looks good, and does not fade like some of the LC trim I have seen, I think the LC trim did not have a factory wood option, so if it has any, it is port installed or dealer/aftermarket stuff. Supposedly the LX leather is better, but I'm not sold on that.
