Here are .PDF showing the "real" GEMI clamps I used to get.
H. W. Eckhardt is the "master distributor".
9mm width band:
http://www.hweckhardt.com/old/clamps/ABA_9mmGemi.pdf
12mm width band:
http://www.hweckhardt.com/old/clamps/ABA_12mmGemi.pdf
Now to really confuse things!
Here are "Norma Torro (Gemi)" clamps. They physically say Gemi Germany on them, but don't have the yellow zinc screw:
CR12 - GEMI Hose Clamp - 9mm Wide [CR12] - $1.36 : Bel-Metric, Metric Hardware, Metric Fasteners, Metric Bolts, Metric Nuts & Time-Sert Thread Repair
Here are full 304 stainless clamps in 9mm and 12mm band:
STAINLESS Norma TORRO 9 & 12 : Bel-Metric, Metric Hardware, Metric Fasteners, Metric Bolts, Metric Nuts & Time-Sert Thread Repair
The small stainless 9mm are ABA, the 12mm are "Norma Torro".
EDIT: Score! - I found a supplier for the 316 stainless ABA clamps, even tiny ones!
ABA Hose Clamps, Ultimate Garage
Read up:
ABA Hose Clamps
"The ABA Original Clamps with their wide smooth bands and stainless steel construction are the best coolant hose clamps you'll find anywhere."
"All ABA clamps sold by Ultimate Garage are 100% stainless steel. Beware of cheaper brands that utilize a stainless steel band with a carbon steel screw....mixing the two materials can result in galvanic corrosion and premature clamp failure."
"Finally, choose and use the clamps properly. Size the clamp so that approximately 1/8" (3-4mm) of band protrudes beyond the worm drive when the clamp is fully tightened. Clamps should be torqued properly to assure proper seal - for all ABA Original Clamps through size #6, use 25-30 inch pounds; for Original Clamps sizes #8 through #16, use 30-40 inch pounds and for sizes #20 and higher, tighten to 40-45 inch pounds."
He does not stock the 304 stainless due to the 316 being same price roughly.
Also, the 316 have more sizes available.
Another source for ABA:
ABA HOSE CLAMPS MENU PAGE
Very informative page:
ABA ORIGINAL HOSE CLAMP 12MM
The trick is to find the ABA "Original Stainless" in 316 from more suppliers.
West Marine carries them for $$$ (Ultimate Garage is MUCH cheaper):
ABA OF AMERICA Heavy-Duty 316 Stainless-Steel Hose Clamps | West Marine
