80 axel swap question
Steamboat Springs, Colorado
Hi,
I’m looking at some point to swap my front axel on my 60 for an 80 with coils. I’m in no hurry but I just came across a couple of decent looking axels from a 96 fj80. When I was reading up it looks like pre 4/94 are the preferred but the others can work with modifications to the hub and birfs.
Can anyone quickly explain the mods and why I could not run as is? Also could I just run the thirds on these for the 4.11 gear ratios? Just seeing if this are worth my while. Thanks a bunch
Unfortunately you can't just pop the third members in your axles. The FZJ80 uses a smaller front axle - 8" I believe. You also can't use the rear differential, because it's a full-floating differential and has no way to support the c-clips that hold your axle in.
You CAN use the FZJ80 rear differential in your front axle, oddly enough.
Thanks. I appreciate it
you want the 91-94 version because you can put the Aisin locking hubs onto those birfields. Although you can always put 91-94 brifields into a 95-97 axle.
the 93-97 rotors and calipers are bigger then 91-92 so those are desirable (unless you want to stick with 15" wheels)
At this point in life the axles and birdied need to be replaced anyway.
So just the axle housing thats available
Just run terrain tamer parabolic leafs they ride nice enough. It would save you a lot of trouble unless you really want coils.
I think that’s going to be my move
I think you better do some research. If you want easy that a good move. If you what the best ride coils are the way.
In my opinion the real benefits of the 80 front axle in a 60 are the additon of panhard bar (no more axle shifting left and right like with leafs), bigger brakes, and decreased turning radius / improved ackerman, as well as the lighter weight and way higher clearance front differential . The coils are just a extra bonus.
