80 Alloy Wheel Identification
TX
As some of you know, my LC was hit recently on the right side.
The RF wheel ended up with some deep surface gashes so I went to install the identical looking 16" rim that I have as my spare.
The strange thing is that instead of having a flared hole where the lug nuts attach to the stud, it's a flat surface around the hole on spare's wheel.
All other 4 wheels have the flared holes and conical lugs.
Being as my '91 has been cosmetically updated by the PO to a '97 inside and out, I'm not sure which alloy wheel(year designation) has the flared opening.
It's not a major problem but it definitely is a less secure fit with the conical lugs attached.
Here's a pic of the spare's flat surfaced hole:
I believe the flat surface rims were a '96 and '97 design. The conical nuts were on the earlier 80s. For saftey sake run the right nuts with whatever rim is on the truck or get a 5th rim to match the others.
DO NOT use conical nuts on that wheel.
That is a 95-97 wheel. The wheels with the tapered inserts are 93-94 wheels.
Go get 6 90942-01077 nuts from your local dealer.
Thanks guys.
I do not currently have the spare mounted.
Was sorta hoping the 4 wheels on mine were the newer versions, oh well. Makes me wonder why the change? If any safety issues had occured, etc. The flat rim/nut seems like it would be a better mating surface.
What I'll prolly do is look for someone willing to swap out the older alloy for my spare's rim.
Not really a priority right now, having an awful time locating a RF pass door in white, 045 color code.
Had no idea it would be this challenging. Painting is not a big deal, but swapping parts is much easier considering the door jam situation and fresh paint blending with rest of vehicle. Thanks for the info, this site is always an education.
Thanks for the part #s cdan, if I can't swap it out I'll be ordering them from you along with some new white fender flare belting.
