- Joined
- Jan 10, 2013
- Threads
- 16
- Messages
- 336
Not sure how much interest this will get, but figured I’d toss it up. I always liked the bags, especially for towing convenience. Mine are also in quite good shape, Pacific Northwest weather probably playing in my favour here.
The axle was a pull out of a 2011 4Runner trail with a front end collision, so I expected it to be fine and so far has been. I had a Elmkeith PCK welded on, and have Treaty Oak KDSS spacers. My drivers side KDSS piston bushing was worn through on the bottom, so I replaced both and kept the good one for a spare. The axle came complete with rotors so I didn’t have to buy those. I swapped my calipers and put new pads on since I was at it. Ebrake hardware I just picked the best of what there was from the two trucks. A friend blasted it for a case of beer, and put some random grey marine epoxy on it he was spraying anyways as a freebie, and I threw some tremclad over that just to make it black. Dunno if it will hold well, but don’t care. I got the factory switch and plug and play harness from Wil Oberdick at Dark Illusions Fabrication, and I also used a CH 4x4 locker switch in series as the factory switch doesn’t give much protection from an accidental actuation without the ECM part. To run it, you press the switch, and turn the dial. When it has locked in, the light on the switch is illuminated giving a visual indication it‘s locked. I also linked the axle and locker breathers, and ran them up near the gas filler, far beyond where I would ever get them submerged. The airbag spacers I had made by another friend, they use a M10 bolt on the bottom to bolt to the spring seat, and the top hole is a near friction fit for the bottom pins of the airbags. It also has a set screw that puts some further torque on the airbag pins, I don’t think I’ll ever pop one out with the way I drive.
