- Joined
- Apr 21, 2005
- Threads
- 115
- Messages
- 25,823
Got a fun summer of driving with the Foyota, although with it's still growling old drivetrain. But a new winter for projects is just around the corner. From some inexact but decent measurements taken this morning, I'm finding that the 55's OAL from machined forward face of tranny to the rear face of the brake drum is about 21 5/8", The same setup from the 60, which is actually shorter measures close to 20 5/8". Maybe I could drive home from my mechanic friend's place with an inch more splines showing. From the front face of the trans to the front driveshft face is about 4 1/4" on both the 55 and 60, so driving home with front wheel drive is a no brainer. But, what comes into my head is that a 1" spacer, maybe even a 1/2" spacer between the flanges could actually incorporate a brake rotor. Now I'd only need a place to anchor a Willwood manual lever operated caliper for an E brake. I used the wilwoods on my skidsteer with simple fabbed mounts and some used honda rotors. Very effective setup. I'm wondering if others have done this mod. The need to make up an inch or so leads nicely into the disc parking/ebrake.
Over all haven't heard good things about the exposed disc brake that mounts to the back of the transfer case. Think I would start searching for a split transfer case hand brake components. Another thing to keep in mind is 8/84 the bolt pattern on the on driveshaft changed. Not sure of the date of the 60 series T&T.
